Injector dynamic ID1000's used on dyno only
Selling my ID1000s
bought from tuspeed, have been used for tuning on dyno but too small for my needs and have upgraded to 1650cc.
were for an r32 gtr but i imagine would suit other applications. comes with plugs as well.
part number: 1000.60.11.d.6
Price: 720 posted aus wide
pickup in moonee ponds vic or west melbourne(during business hours)
Edited by will34
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
