  • 5 months later...
So, I've been a busy boy in between running a business, being an adult and shit like that.
so here goes!
since I last left off, I had gotten my hands on a wrecked shell and scavenged the parts I needed from it.
following this, we had the chassis rail pulled straight (with no resistance) and had the rest repaired.
thats when the fun started.
the car has been hit on that side before, hard.
this made unpicking a nightmare! But we got it done, it isn't pretty, but it's done.
Painted the bay bay this week end, and now starts the assembly stage! We're getting closeeeeeeee
  • Like 5
  • 3 months later...
Update:
progress has been slow, but we’re getting there
im still slowly accumulating parts, managed to pick up a really tidy steering wheel and original wing and not pay drug money, but more importantly, the car is now sitting at my panel beaters, waiting for the boys to have a crack at some body repairs and paint.
i can’t seem to find out which is the correct shade for the car, but it’s been smashed, repaired etc so f**k it. I’m going for the nicest TH1 there is, standard base with a lighter, greener flop.
same delicious TH1, with very very slight aqua tones at different angles
We should start moving quickly from here, I hope.
  • Like 2
2 hours ago, Robzilla32 said:
How do people find stuff like this?
Presumably to get that price you had to swallow as well?
I still don’t know, ebay.. I saw them and just put my maximum bids in, someone had a go at the wing but nobody bothered with the wheel..
also picked up an R34 GTR intercooler, couldn’t be bothered paint stripping the original one lol
  • 1 month later...
Long time no post, you’re all probably used to that by now.
the car is now at the panel shop.
it seems that one of the previous owners had tried to roll the guards and warped the steel above the arch, so I went ahead and gave them a proper roll.
the boys at the panel shop will fix this.
We’re going to begin repairing, rubbing etc this week end and hopefully have it painted in a few weeks.
i guess the great part of a close friend being your panel beater is that he wants it perfect.
so he made me rub the entire bay again.....?
  • Like 1
Had all of the intake stuff apart and cleaned up.
gave it a coat of KL0 and clear, came up looking awesome.
also, found some crusty rust and bad repairs.
typical area around the tail lights, but the previous owner tried to pack it out with sikaflex...
  • 4 weeks later...
  • 3 months later...
Hello friends, long time no post.
I guess things really do take time when they’re done properly.
the car has had the required rust repairs and is now ready for high fill.
i know the bog looks bad but it’s only a skim of fine filler. Only so much the lads could do without replacing the quarter panels etc.
the car has had a bad quarter change in the past, with both panels lined up and filled with weld. I had the tedious task of cleaning the canyon and getting it prepped for brass, followed by some of weirdest filler I’ve ever seen- that fibreglass looking stuff is actually aluminium infused filler that is being used on bmws now!
take note of the rust hole on the pilar, it looks like this is a problem area on a few GTRs due to the location of the factory window trim clips holding dirt and moisture. This let water trickle down into the boot channel, and then down the beaver.
bought a set of rays gramlight 56crs in 18x10.5+12, yes, they’ll fit. I don’t care how it’ll drive, it’ll look shit hot haha.
pic dump
  • Like 4
Repairs are DONE!
Body is in high fill!
engine bay in boot is looking f**king silky.
spent the last couple of days helping out at the panel shop and doing a little more on the hoist ;)
  • Like 1
  • 1 month later...
  • 2 months later...
finally got some rubber on the tyres, they fit good.
body is painted, parts next and then it’s on it’s way to my warehouse to be finished off.
paint came out like glass ?
  • Like 4
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
