  • 5 months later...
So, I've been a busy boy in between running a business, being an adult and shit like that.
so here goes!
since I last left off, I had gotten my hands on a wrecked shell and scavenged the parts I needed from it.
following this, we had the chassis rail pulled straight (with no resistance) and had the rest repaired.
thats when the fun started.
the car has been hit on that side before, hard.
this made unpicking a nightmare! But we got it done, it isn't pretty, but it's done.
Painted the bay bay this week end, and now starts the assembly stage! We're getting closeeeeeeee
  • Like 5
  • 3 months later...
Update:
progress has been slow, but we’re getting there
im still slowly accumulating parts, managed to pick up a really tidy steering wheel and original wing and not pay drug money, but more importantly, the car is now sitting at my panel beaters, waiting for the boys to have a crack at some body repairs and paint.
i can’t seem to find out which is the correct shade for the car, but it’s been smashed, repaired etc so f**k it. I’m going for the nicest TH1 there is, standard base with a lighter, greener flop.
same delicious TH1, with very very slight aqua tones at different angles
We should start moving quickly from here, I hope.
  • Like 2
2 hours ago, Robzilla32 said:
How do people find stuff like this?
Presumably to get that price you had to swallow as well?
I still don’t know, ebay.. I saw them and just put my maximum bids in, someone had a go at the wing but nobody bothered with the wheel..
also picked up an R34 GTR intercooler, couldn’t be bothered paint stripping the original one lol
  • 1 month later...
Long time no post, you’re all probably used to that by now.
the car is now at the panel shop.
it seems that one of the previous owners had tried to roll the guards and warped the steel above the arch, so I went ahead and gave them a proper roll.
the boys at the panel shop will fix this.
We’re going to begin repairing, rubbing etc this week end and hopefully have it painted in a few weeks.
i guess the great part of a close friend being your panel beater is that he wants it perfect.
so he made me rub the entire bay again.....?
  • Like 1
Had all of the intake stuff apart and cleaned up.
gave it a coat of KL0 and clear, came up looking awesome.
also, found some crusty rust and bad repairs.
typical area around the tail lights, but the previous owner tried to pack it out with sikaflex...
  • 4 weeks later...
  • 3 months later...
Hello friends, long time no post.
I guess things really do take time when they’re done properly.
the car has had the required rust repairs and is now ready for high fill.
i know the bog looks bad but it’s only a skim of fine filler. Only so much the lads could do without replacing the quarter panels etc.
the car has had a bad quarter change in the past, with both panels lined up and filled with weld. I had the tedious task of cleaning the canyon and getting it prepped for brass, followed by some of weirdest filler I’ve ever seen- that fibreglass looking stuff is actually aluminium infused filler that is being used on bmws now!
take note of the rust hole on the pilar, it looks like this is a problem area on a few GTRs due to the location of the factory window trim clips holding dirt and moisture. This let water trickle down into the boot channel, and then down the beaver.
bought a set of rays gramlight 56crs in 18x10.5+12, yes, they’ll fit. I don’t care how it’ll drive, it’ll look shit hot haha.
pic dump
  • Like 4
Repairs are DONE!
Body is in high fill!
engine bay in boot is looking f**king silky.
spent the last couple of days helping out at the panel shop and doing a little more on the hoist ;)
  • Like 1
  • 1 month later...
  • 2 months later...
finally got some rubber on the tyres, they fit good.
body is painted, parts next and then it’s on it’s way to my warehouse to be finished off.
paint came out like glass ?
  • Like 4
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
