  • 5 months later...
So, I've been a busy boy in between running a business, being an adult and shit like that.
so here goes!
since I last left off, I had gotten my hands on a wrecked shell and scavenged the parts I needed from it.
following this, we had the chassis rail pulled straight (with no resistance) and had the rest repaired.
thats when the fun started.
the car has been hit on that side before, hard.
this made unpicking a nightmare! But we got it done, it isn't pretty, but it's done.
Painted the bay bay this week end, and now starts the assembly stage! We're getting closeeeeeeee
  • Like 5
  • 3 months later...
Update:
progress has been slow, but we’re getting there
im still slowly accumulating parts, managed to pick up a really tidy steering wheel and original wing and not pay drug money, but more importantly, the car is now sitting at my panel beaters, waiting for the boys to have a crack at some body repairs and paint.
i can’t seem to find out which is the correct shade for the car, but it’s been smashed, repaired etc so f**k it. I’m going for the nicest TH1 there is, standard base with a lighter, greener flop.
same delicious TH1, with very very slight aqua tones at different angles
We should start moving quickly from here, I hope.
  • Like 2
2 hours ago, Robzilla32 said:
How do people find stuff like this?
Presumably to get that price you had to swallow as well?
I still don’t know, ebay.. I saw them and just put my maximum bids in, someone had a go at the wing but nobody bothered with the wheel..
also picked up an R34 GTR intercooler, couldn’t be bothered paint stripping the original one lol
  • 1 month later...
Long time no post, you’re all probably used to that by now.
the car is now at the panel shop.
it seems that one of the previous owners had tried to roll the guards and warped the steel above the arch, so I went ahead and gave them a proper roll.
the boys at the panel shop will fix this.
We’re going to begin repairing, rubbing etc this week end and hopefully have it painted in a few weeks.
i guess the great part of a close friend being your panel beater is that he wants it perfect.
so he made me rub the entire bay again.....?
  • Like 1
Had all of the intake stuff apart and cleaned up.
gave it a coat of KL0 and clear, came up looking awesome.
also, found some crusty rust and bad repairs.
typical area around the tail lights, but the previous owner tried to pack it out with sikaflex...
  • 4 weeks later...
  • 3 months later...
Hello friends, long time no post.
I guess things really do take time when they’re done properly.
the car has had the required rust repairs and is now ready for high fill.
i know the bog looks bad but it’s only a skim of fine filler. Only so much the lads could do without replacing the quarter panels etc.
the car has had a bad quarter change in the past, with both panels lined up and filled with weld. I had the tedious task of cleaning the canyon and getting it prepped for brass, followed by some of weirdest filler I’ve ever seen- that fibreglass looking stuff is actually aluminium infused filler that is being used on bmws now!
take note of the rust hole on the pilar, it looks like this is a problem area on a few GTRs due to the location of the factory window trim clips holding dirt and moisture. This let water trickle down into the boot channel, and then down the beaver.
bought a set of rays gramlight 56crs in 18x10.5+12, yes, they’ll fit. I don’t care how it’ll drive, it’ll look shit hot haha.
pic dump
  • Like 4
Repairs are DONE!
Body is in high fill!
engine bay in boot is looking f**king silky.
spent the last couple of days helping out at the panel shop and doing a little more on the hoist ;)
  • Like 1
  • 1 month later...
  • 2 months later...
finally got some rubber on the tyres, they fit good.
body is painted, parts next and then it’s on it’s way to my warehouse to be finished off.
paint came out like glass ?
  • Like 4
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
