VH41DET r32
Hi,
I've spent the afternoon searching the forums for info on a vh 41 conversion into an r32.
I've found lots of topics on people doing it in racecars, or people talking about doing it but never posting the finished product.
I'm just wondering if anyone has done it in a street car and if there are  any businesses experienced in doing it? It's something i'm very interested in but the quotes i've gotten locally are insane because no one has done it before.
Just hoping someone can point me in the right direction.
Thanks!
https://www.sau.com.au/forums/topic/467026-vh41det-r32/
There's a few around and its pretty straightforward - the bell housings are available over here and no doubt in Aus as well. If you're going to pay someone to do it it will cost an arm and a leg. But why bother? An RB30 makes much more sense..
This is an R33 but its much the same:
http://www.trademe.co.nz/motors/used-cars/nissan/auction-1163792991.htm
and this is an R32 but  VK56
http://www.trademe.co.nz/motors/used-cars/nissan/auction-1166480588.htm
  • Like 2
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779666
Search through the N/A section.  There's a VH45 conversion owned/run by Captain Natro, who (I think) is maybe from the Toowoomba area also.
If it had to be a Nissan V8, go VK56.  Cubes count.
On that front, go LS.  7 litres of goodness.
If you want to keep sanity, as per Bob's suggestion go RB30DET.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779670
1 hour ago, Malek41 said:
Search up mcmtv2 on YouTube and they do a vh41 swap in a stagea. Very very detailed so hopefully that should help
Complete with turbo - a great job but they are not willing to put a dollar amount on it - would probably be north of $100,000! - although AWD added to the complexity.
Here's the video - there's  about 12 episodes I think:
  • Like 1
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779704
Only issue is I want it turbo and engineered all I have to keep low capacity.
Yeah I've watched all of them but I figured that rwd would have to be much more straightforward.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779795
I just had a look at captain natro, he is in Toowoomba, I know how car. Pretty sure it's got an ls though.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779798
OK, let me put it another way.  You want more cubes.  VH41 is old old old tech, common era with RBs pretty much.  VQ is the new hotness.  Provides most of the "more cubes" you could get from the VH but with a whole lot more modernity, more compact dimensions, ease of making exhaust manifolds and turbo locations and blah blah blah.  Lovely 6 speed gearbags available.
https://www.sau.com.au/forums/topic/467026-vh41det-r32/#findComment-7779877
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
