Blown Neo head gasket - Next steps?
Ok so I am 95% certain I have blown the head gasket in my Neo.
Symptoms:
  • The engine is pushing coolant into the overflow bottle when pushed even moderately. I tried it out at Sandown today with an eye on the temps at all times and returned back to the pits whenever it hit over 90C -> overflow is at max or beyond. I added a second overflow bottle for the day too.
  • Coolant in the overflow bottle not clean/clear, it's bubbly/foamy after a run, and also there's occasionally 'floaties' (black sediment) on the surface. Doesn't smell the best either; not quite like combustion gases but not like clean coolant either.
  • I also noticed that the exhaust is popping on more than usual on gear changes, running rich perhaps? Also it doesn't feel like it's hitting/holding boost quite as well as normal (not that I pushed it a 100% but still). Unsure if this is related.
What's weird is that I had a tee kay test done earlier this week and it came back all clear. Comp test was 155,155,155,140,146,150 so not top of class but within the 10% tolerance.
The back story is that I had a small coolant leak at Sandown last time two months ago -> lost coolant and pressure -> temps shot up to 125. What I'm not 100% sure about is whether that's the root cause. The engine is currently at 153,000 kms and it's been running ~20psi for the past 20,000 kms, with about half a dozen track days on it.
Now, to the questions.
I know that I'm up for a head gasket and head studs at a minimum, plus probably a head skim. Some would recommend a head reco too.
  1. With the studs, I'm guessing ARP over OEM?
  2. With the gasket, OEM should do with stock bottom end at up to low-300 kw's, no? From what I understand it's a bit more forgiving to an uneven surface than a metal one.
  3. Where in Melbourne should I go for some quotes, who knows this stuff well? What should I expect to pay?
Also, some other options:
  • An alternative to all that work is just buying another Neo, which can probably be had for say 2k? Lots of labour to change it over though, plus the condition would be anyone's guess. Or just go crazy and buy someone else's 24/30...
  • What else might I look at doing when the head is off? Built bottom end would be nice but gets pricey very quickly. Also poncams would be cool but I'm not sure how much they add without any other mods.
Anyway all I really want is a track ready ~300rwkw @ 98 car that is reliable...
Thanks guys! Also big hat tip to Bill and Greg for troubleshooting this with me at Sandown today!
https://www.sau.com.au/forums/topic/467066-blown-neo-head-gasket-next-steps/
If your not going to go crazy with the boost levels
Stock headbolts will be fine unless you plan on running more than 22psi closer to 25psi
Would get away with a head skim and genuine headgasket unless it was blowing smoke or burning oil i wouldnt bother getting the head serviced
Expensive job especially on a 6cyl
You can usually tell by the spark plugs
The cylinders that are blown will be very clean
You cant always tell using the tk tester but if the cooling system is bled proberly and not blocked shouldnt push coolant
Another way to test is with a pressure tester connected and running the car the pressure should be steady
  • Like 2
Thanks mate. Not blowing smoke or burning oil, although there was some oil residue on the #2 plug when the guys checked it earlier this week.
The system has been bled multiple times and seems to behave itself on idle, it's just under load when it starts pushing coolant.
Is there any chance a blocked radiator or hose somewhere could cause symptoms like these? I'd hate to get the head gasket done and not have the issue fixed...
Have you got a new radiator cap? Have you had a new radiator? Go to a radiator shop and get a pressure test then get them to take the top tank off and clean out the radiator or recore as necessary. You're going to feel really silly if you replace the engine and nothing changes.
  • Like 2
11 hours ago, AngryRB said:
Check the Head isn't warped...
Yeah will do – silly question but I assume there's no way to check without pulling it off?
Yes brand new Tridon cap put in on Friday. It's got the original radiator still, it passes the pressure test fine. What's a good replacement worth? When you say 'top tank', are there multiple parts to the rad?
I would go ARP non 2000 studs if the head is coming off. Good clamp is good for keeping thr head and block together. Never know, one day you might have the urge to push out 350kw+ lol
Yeah there's a good chance haha :)
I'm currently thinking:
  1. Replace radiator and hoses & see how it goes
  2. If still no good remove & skim head (no reco), re-install with OEM gasket and ARP studs
The thing that concerns me is the bad smell & sediment in the coolant, that doesn't feel like a radiator-only issue. Unless there's a blockage somewhere and the pressure is pushing the crud collected over the 150k around?
5 minutes ago, GTSBoy said:
Oil water heat exchanger failure is a possibility.
Hmm it's been changed early this year as the original one was leaking. However, I think the 'new' one is second hand too so you never know.
Because of the pressure differential (oil 2-6bar vs. coolant ~1bar) I'm guessing it'd mix oil into the water rather than the other way around? I'm not seeing any loss of oil at the moment.
Here's what the overflow looks like after a drive, it does smell like exhaust and there's dark gray matter near the bubbles. It pushed about an inch from the radiator into the overflow during the drive.
Hey, could you give me a heads up on why go non 2000 studs?
Thanks
  • Like 1
Thanks
because budget conscious track build and they're fine... ARP 2000 for big power and boost.
Since the head is coming off, might as well do value stem seals and also basic performance valve springs... RB25DET is prone to valve float once it gets some heat into it.. sometimes noticeable on the dyno after many pulls usually only noticed on the track.
  • Like 2
9 hours ago, Scott Black said:
Have you also done a leakdown test on the motor?
Nope, just a comp test and the tee kay. Should I get a leakdown done, what's the benefit?
Also I just checked yesterday on cold start that the car is not blowing any smoke just at least that's good..
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
