That's a lot better. I still reckon diy is the way to go. Oem gasket, arp studs. Save the 2-2.5k for other improvements, upgrades, track day fees etc. At least do a bit of research in what's involved. It's not that hard, just time consuming.
Just now, GTSBoy said:
There's a few things that I would do if I got the engine into that many pieces.  Better valve springs is one of them.  Some thought put into the oil pump/drive would be another.  Worth a thought while it is accessible.
Cheers mate, definitely valve springs.
The hope is that the bottom end stays in the car, I thought the oil pump was an engine-out job?
Cheers Bill. Just reading through some threads, it is a big job, I didn't realise the whole hot side, timing gear etc. has to come off too:
Can be done with motor held up by gearbox and gearbox on some form of stand as well as those on strut top engine stands (don't know what they're called) then drop the x member followed by the sump.
Easier motor out lol
If I'm changing the oil pump on an rb chances are its also getting new bearings as a minimum so it's just so much easier to work on out of the car.and really compares to supporting the motor it's the same time.to just pull the engine out. Yet I have workshop acess so that changes things alot
  • Like 1
If were mine, id not bother with oil pumps and springs etc, id skim head and have inspected, then slap the lot on a running RB30 bottom end.
RB30- $300 , modding for tensioner, belt, pwr steer bracket, slot mounts- $200 , vct and shave head $200, oem gaskets and bolts - $300
Also take the engine and box out in one go would be quicker.
Edited by AngryRB
  • Like 1
I guess an important question is actually what are the long term plans, as any of the options listed when not diy become very expensive very quickly, so if you don't have any major plans for big power in the forceable future just get it checked out properly and fix the issues it has without upgrading everything if however you want to mod it and make decent power then it's going to get expensive yet it's best to start now so not paying twice
Now this is the $10,000 question, spot on.
This car started as a family car and then steered towards a cheap track car. It's been a decent family car and ok on the track but never cheap.
Whilst I'd love to have a scary 400rwkw monster, I'd pick a reliable 300rwkw over that any day.
Reliable and balanced 400rwkw would mean forged bottom end, new injectors, new fuel system, new turbo, new intercooler, then the clutch is going to so new clutch, probably tail and drive shafts, and potentially some new gearbox internals. Then a flex fuel setup so a new ECU and 2x full tune. New brakes too, and to get those in, new bigger wheels x2 sets, one for the street and another for the track. That's 20-25k gone easy. At that point, if really chasing times, the better deal would be to sell and buy a properly sorted mildly built Evo, it's just the quicker platform.
Plus frankly, the car is currently not the limiting factor in the least (besides reliability) - it's the driver. All I really need is more seat time, with the hope that I wouldn't need to keep on fixing the thing after every single outing like I've had to this year.
So the short answer is, just fixing it properly without major upgrades is probably the way to go.
  • Like 1
Very little progress. First quote was too expensive, second quote ok but very busy so still haven't been able to book the car in, third quote never got back to me. Sigh.
Any recommendations for workshops or mechanics in Melb who a) can do this b) want to do this c) are not crazy busy and d) don't charge an arm and a leg?
Tough ask I know. PM's welcome of you don't want to promote in public.
Good workshops are busy. It's just the way it is.
Are you asking to just get the head gasket done? Or talking about doing that other stuff aswell?
Yeah very true.
Looking at doing the list above ie. confirm it's the HG and then go from there.
On 03/10/2016 at 0:01 PM, V28VX37 said:
In terms of rad this has been recommended but it's not exactly cheap: http://www.prospeedracing.com.au/products/mishimoto-nissan-skyline-r34-performance-aluminum-radiator.html
On 03/10/2016 at 0:29 PM, WMDC35 said:
I've been using one of those radiators for about 5 years, no issues
Does anyone have thoughts on the benefits of a Mishimoto/Koyo Racing/similar rad over a basic Cooling Pro from Just Jap? http://justjap.com/engine/cooling/radiators/cooling-pro-alloy-radiator-nissan-skyline-r33-r34-stagea-rb25-rb26.html
As far as I can see both are triple core 40mm drop-in replacements but the Mishimoto is twice the price of the Cooling Pro.
eBay ones work okay, if money permits get a better one however I ran a Worley one for years on the track only ever boiled coolant on warmer days.
However since I've gone to a PWR one I haven't seen the water temp move past 100 degrees on the track.
  • Like 1
I went with the Mishimoto hoping that the fitment is a bit better. Paying workshop labour you'll easily lose any savings as soon as you have to muck around during the install.
Ordered some OEM rad hoses too just as a precaution.
  • Like 1
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
