Yuh, that's just a sheathed TC passed through a gland.  The screwed fitting at the very top (female part) is the gland seal.  The TC is very short, so it would be trivial to not insert it far enough.  Just loosen it and see if it can be pushed in further.
  • Like 1
20 hours ago, admS15 said:
According to tampered motorsport website apparently there is a sandown track day on the 11/12. I may sign up for that once I have my car running again.
Some of us other SAU's might join you on this day :) Either that or rexmas pending on the amount of cars entered
11 hours ago, V28VX37 said:
Sorry mate manic today and over the weekend but Sunday night could work? Unless you must buy tomorrow :)
We'll keep in touch :)
Cool, will keep an eye out on both events and touch bases before committing to anything.
Just pulled out the sensor then, it was pretty stuck with the constant heat expansion/contraction. The probe sticks out a good 25-30mm and I don't think it's ever moved since installation (nor could I move it) so it's not the positioning. Also the gauge doesn't move anymore at all (no error light either) so somehow the sensor just decided to die now.
A genuine Defi replacement is like $250 so I reckon I'll try a cheapo eBay replacement next to see how long it lasts.
  • 3 weeks later...
No.  Take it to IPA (Industrial Pyrometers Australia) or any equivalent place near you and say, "Please sir, make me one of these."  Will cost ~$50.  Will be proper.
Did exactly the opposite, ordered cheapie off ebay, butchered original sensor wire to get the connector, only to find out that the probe itself won't fit through the Defi bung in the first place lol
I was googling industrial pyrometers and a few companies came up, if you've used one in Melb before which one was it?
  • 5 months later...
1 hour ago, -S- said:
Apologies for hijacking but quick one...( instead of starting a new thread) , can i apply this on a r33 rb25det? Basically arp head bolts and studs and oem head gasket for a bone stock 380rwhp street car.
500hp street setup
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
