HiLol...was a rev up since he doesnt want to share any info. I am guessing he will install bleed nipples before he tries to chirp 3rds :)
Looks like Cayenne calipers on a 324-332mm rotor of sorts as it all still fits under a 17" wheel.?!?!?!?!
Probably work quite well on the smaller rotor. Problem with Cayenne calipers is they come with varying piston sizes depending what model Cayenne they are off.  You need to have the ones with the smallest pistons to have a real chance of it being a good bolt on setup otherwise without ABS it will just be locksville
There are adapters available now to run the brembo 17z or 18z calipers with z34 355mm rotors for Z / S / R (non gtr only) chassis cars. Also kits for gtr's (& Z/S chassis) to run AMG 8 pots with the 355mm discs
Great work designing your own to work with gtr's though
Edited by lidz
21 hours ago, GD51LA said:
that's allot of man hours that i don't want to give away
i could sell you a kit front and rear for approximately 4k
How does this benefit anyone if you're not willing to share any information? What's the point in even posting about it then?
wheel stud hole need to be drilled to nissan stud pattern
these are the smaller cayenne calipers designed for 330mm rotors off the v6 cayenne (330mm cayenne rotors)
the pad meets perfectly with the rotor surface
anything else?
Yes. Where did u get 4 grand from as an asking price and what advantages do you see in these over the evo brembo kits, and what master cylinder have you found a skyline to require during your testing of this prototype kit.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
