RB25DET strange oil reading
Hi all ive encountered a bit of a strange issue in my 33. Ok heres the scenario. Last week started it up to go to work car started ticking like it had no oil so i shut it down and went to check the dipstick to my horror i found it was just under the low sign so i topped it up.. and went on to work. Being parranoid of burning oil i checked the level once i got to work which is a fair distance of about 55km it strangely read above full. Since then ive been monitoring it day by day on the 4th day i noticed it droped to about 3/4 full and by the 6th day in the morning i checked it it was at the low sogn again. I had run out of oil to top up so i head over to the local parts store to buy some more then went home i got distracted and had to do a few things but once they were done i proceeded to check my oil level again to my dissbelive i found the oil level at the full mark. Could i have possibly have a blockage? Have anyone had this issue? Its a 95 s1.5 un opened engine with 150xxxkm all bolt on and suport motor 330kwatw gt3582r no sump mods definently the original dipstick
https://www.sau.com.au/forums/topic/467080-rb25det-strange-oil-reading/
Are you parking it on a flat surface when you check it? What grade oil?
Ive checked mine on my driveway, which has a slight slope before and oil was low. But back on flat ground was fine
I know its simple shit but have to start somewhere. Thicker oil takes longer to drain back. Give the first situation in your story the oil was cold may suggest not all the oil had returned to the sump. If it were me, i would check it, drive it, park on flat ground and after a while check it again.
Do that a few times. Check for blowby etc.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
