absolutely, the block and cradle are a pair. Even when they come together from the the same engine they should still be measured and potentially machined to make sure the main bearing clearances are correct.
  • Like 1
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7780959
so what can i do ? i have a block but no cradle, does that mean my block is useless ? do i just need to find a cradle and get it machined to suit block ? can i buy a new cradle from spool and get that machined to suit ? im lost
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781608
Would almost be easier to keep your eye out for another complete block.. There's quite a few on facebook sale pages at the moment.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781610
I know it's not great news, and no you are not lost, they are pretty much your choices.  I'd either buy a different block (probably cheapest option) or buy a new cradle if that's an option (I assume its aftermarket and a different style). If you choose the latter you need to get the block tunnel bored which I don't really like in these engines because it moves the crank relative to the oil pump
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7781979
12 hours ago, Scott Black said:
with that ill just need to tunnel bore it right ? my block is 87mm and already been machined and cleaned n decked, so im not looking to buy another block, most likey just buy that girdle and machine it to suit right ?
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782314
I could be wrong but I'm pretty sure you need to buy the Spool girdle in conjunction with their main cap kit which is another $1600 or so.  I could be wrong but I'm pretty sure that's how it works.  You can get the mains on their own but not the girdle on it's own.
https://www.sau.com.au/forums/topic/467094-rb30-girdle/#findComment-7782322
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
