  • Replies 112
$2000 to rebuild ur stock turbo or $2400 for a nice new twin ball bearing garrett GT30.
I know what i would be buying and did buy.
If u r serious go external gate, you know you will get bored eventually and get one in the end :)
Not everyone has the money to throw around on a new manifold and external gate.. Thats why I chose the rebuild option... 250RWKW and above is plenty for the street..
lepperfish what boost and mods are running to get 265rwkws? im running the same turbo and im nowhere near that power level!
Hi carl, I have ecu, fuel pressure reg, 600hp fuel pump, gcg 450hp turbo,
runs 20psi all the time..
I got a GCG 450hp turbo and it makes around 265kw at wheels..
If your making that sort of power out of a GCG high flow, and your car isnt a freak :rolleyes: then id say hell the decision is obvious as thats pretty damns close to 450hp at the engine.
Looks std, save the expense of the manifold wastegate etc etc....if you dont have to go aftermarket manifold and wastegate to get your power then that saves so much agro, problems with controlling underbonnet temps, concerns over cracking manifolds etc etc.
The GCG high-flow is a new turbo, and the supposed saving of $400, well first you have to sell the std RB25 turbo for that money then have to worry about new piping and possibly modified water lines.
265rwkws...whats the power like, peaky, tractable, the boost you are running, othe rinternal mods????? Man if its a std RB25 with a high flow with injectors then id be interested to hear more, my car needs open heart surgery:)
My car has just had a full engine rebuild.. But was making the same power about before I had the rebuild.. Power is really nice, Have got a tomei adjustable exhaust cam gear as well and full boost is acheived at 3400rpms.
Are You Running Lower Compression To Acheive The 20psi Boost ? Im Running St.1 Gcg 450hp Hi Flow Turbo , 600hp Bosche Motorsport Fuel Pump, Malpassi Rising Rate Reg, Ces Racing Split 3inch Dump Pipe, 3 Inch Cat, Exhaust, Link Ecu , Gtr Intercooler And At 17.5psi Boost My Car Could Only Manage 212rwkws On Shootout Mode , My Tuner Advised Me That I Needed An Aftermarket Manifold To Achieve More Boost And Therefore More Power , He Reckons This Will Give Me Another 15 To 20 Rwkws!!! So At 230rwkws Im Going To Be Still Along Way From 265rwkws Lepperfish What A Freak/ Animal Of A Car Youve Got Mate!!
No, im running standard compression. I have 3 inch exhaust from turbo back, 3 inch highflow cat, custom front mount intercooler, Haltec coil pack, electronic boost control from the haltec ecu.. btw, everycar will react slighty different from similar mods. Your setup might max out at 240 - 250kw, where someone else may acheive 260 - 270kw... Will get you dyno sheet ASAP mate..
Our R34GTT makes ~265 rwkw, just like Lepperfish's does, I have seen another RB25DET on the dyno do pretty much the same. It's not a freak engine, just well tuned with the right mods. My experience is the same, much over 1.4 bar is a waste of time, just makes more heat for no more power. :D
bigcarl,
You do have an RB25 don't you?
Enrico,
If it were myself I would consider either the GCG turbo or the 2835ProS.
Don't let them bully you in to going external gate for an extra 30rwkw's.
Also as a note Grepin is making some where up around 270-280rwkw's with a small .69 exhaust a/r.
230rwkw is no slouch Robo.. When I was enquiring about turbo upgrades for the R33 SK advised me that the 500hp GCG unit would be more suitable for an RB30 application and that the 450hp would suit the Rb25 alot more so therefore I chose that turbo soley on SK's recommendation..
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
