Can I use stock cams in an N1 block?
Gentlemen and ladies
I have an RB26 N1 block and I have stripped down my stock RB26 block.
I would like to build this block as an N1 engine. I am getting my crank blue printed. N1 oil pump and N1 water pump.
Are the N1 cams the same as the stock ones?
i read this on this site.
SKYPER
  • SKYPER
  •  0
  • 120 posts
  • Car(s):GTS-T
N1 cams have the same lift, duration as stock GTR cams but the central angles are different -
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
Can anyone clarify?
thank you.
https://www.sau.com.au/forums/topic/467112-can-i-use-stock-cams-in-an-n1-block/
According to the Tomei chart (as you know) all RB26 cams are the same.
But according to Wikpedia:  . The N1 engine also has upgraded camshafts and upgraded turbochargers.
Hopefully someone with such an engine will enlighten you.
What are you going to use the car for? You may want to think twice before using the N1 water pump.
***** EDIT. Observe strikethroughs below. I proved this incorrect later with an EXTENSIVE dyno session. My car LOVES overlap on powerband. Was able to go 6deg intake advance and 4 deg exhaust retard (CRANK DEGREES...NOT CAM), and the car picked up BIG power in midrange. It does, unfortunately, sound like a cammed out racecar at idle now :).
From what I've read the only changes that Nissan made on the N1 cams are the timing...not with the actual profile. They moved the exhaust cam retarded 5 degree which makes for 5 deg of overlap vs. the factory set 0 for non-N1 cars..but they did this on the cam and not with the gear. So in a sense everyone has N1 cams if you buy an exhaust cam gear and retard it 5 deg at the crank (or 2.5 on the cam).
If you think about it, I think this alone is likely where everyone gets the idea of the cam timing set at "-4 EX, +2 IN" which puts your overlap at 6 deg...when the N1 was 5 deg overlap (all done with the exhaust cam) from the factory. 6 one, half-dozen the other.
But when you add aftermarket cams, I found that going further on overlap started hurting my car's power. For example, my Tomei Poncam A's are 31 deg overlap when set at 0,0. When I tried the typical "-4 EX, +2 IN" It was too aggressive in the mid range and started losing on top. I'm currently at 0, 0 with Tomei Poncam A's. With factory I would have induced some overlap like most people do though. I'm shortly going to hit the dyno and try to advance the exhaust cam to go LESS overlap which should make for a smoother idling car and more power on top end (<---THIS MADE LESS TQ BUT SIMILAR POWER - WAS BETTER POWERBAND WITH OVERLAP!). But really I see no reason to ever be 0 overlap on such a high-revving engine.
I have attached a screenshot of my excel spreadsheet for looking at cam timing changes w/ respect to overall valve opening and closing as well as the spreadsheet.
Cam timing overlap changes.xlsx
  • Like 1
Thank you all for enlightening me.
I have read the N1 engine was specifically built for racing and that the oil pump on the N1 was a higher flow type. Not much about the N1 water pump though. I will not be racing the car. I just want a reliable strong engine as I got the block fairly cheap.
Are the oil pumps prone to failures?
So is the consensus that I can drop the cams from the stock block into the N1?
If I change the cam timing as suggested above to match the N1 what will be the likely effect?
Thank you all again.
I've read the N1 oil pump is better...but I can't confirm. I was not convinced enough to go with it and instead went with Tomei $$$$$$$$.
The N1 water pump just works better at high rpms...not necessarily for a streetcar, but I am running it on my streetcar which sees 8250 rpms every time I drive it and I live in a very hot climate with no issues on the KOYO radiator. It reduces cavitation at very high rpms.
Factory or N1 Cams should work no problem in your motor, just get your shims correct for valve clearance to make sure you are not losing power and are not going to hurt the motor.
Indexing the cams closer together (cam gears move AWAY from each other, but CAMS move toward each other increase the valve overlap which means as the piston is pushing exhaust up out of the cylinder through the exhaust valve, the intake valve will start to open slightly before the exhaust valve is closed...
This results in a few things:
1) At lower rpms the car will run slightly rougher and have slightly less vacuum because you are diluting (slightly) the exhaust and intake streams.
2) At midrange rpms where the exhaust back pressure in the turbine is less than boost pressure, the car will make more torque and power. This will make for a "punchier" feeling car.
3) At high rpms when the turbine starts to make more backpressure than the boost pressure the exhaust will reduce the ability of the intake to inject boost into the cylinder. This means that you will lose some top end power at high end.
So basically when you move the CAMS closer together by increasing how much the valve timing overlaps, (by either retarding exhaust cam or advancing intake cam) you "tighten" the powerband, but you make it more torquey. When you move the CAMS further apart you make the car run smoother around town, and make more power on top end, but it will not be as agressive in the mid-range. I think the N1 setup was for the N1 turbos, and for road racing. They were probably increasing mid-range response because this is what you need in road course racing to pull out of turns.
Yes I think if you retard the exhaust cam 5 degrees on stock cams, you essentially turn them into R33 N1 cam timing.
  • Like 1
There was I believe a run of bad N1 pumps. Some people won't touch them but I have done about 20.000km on one. If I were building a high spec high power high revving engine I would use a Tomei.
The N1 water pump is designed to be efficent at high revs so probably not a good idea in a street car and certainly not better than a new stock pump.
If you are putting stock cams in your engine you could put adjustable gears on both and get them tuned on a dyno for best results.
N1 turbos are laggy which is why the timing of the cams assists bottom end power and torque. As stated above, the top end of the curve flattens a bit earlier.
There's no need for a street car to have a N1 water pump. Save your money. Impeller blades are fewer on the N1 and larger in size. As stated above, they're only more efficient whilst racing.
The N1 oil pump is more efficient than stock but not as robust as some others.
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
