1989 BNR32
1989 R32 GTR  South Australia (close to Adelaide)
AH3 Wine red
150k kms on clock
Rebuilt RB26 15k kms since rebuild, compression 165+ psi
Garrett GT2860r -7
Nistune E85 dedicated 329rwkw, Greddy Profec2 EBC
Brembo Evo brakes front & rear with BM57 master cylinder, calipers rebuilt, powder coated, new 2 piece front rotors(Girodisc), new DBA4000 rear, all new pads & lines
oil cooler & filter relocated, new radiator
R34 Gtr rims X 5
Bride Digo seats(driver & passenger)
HKS front pipe with 3.5inch stainless exhaust
Suspension has all been done front & adjustable rear(whiteline) including subframe bushes, cv joints, rack boot ends, tierods etc etc & Hicas lock
splitfire coils, jim berry clutch, walbro fuel pump, 1000 injector dynamics, apexi pod filters
Everything listed is brand new including hoses & clamps & im sure i have missed gear
All original parts taken off car come with the sale including seats,rims,suspension, brakes plus a set of Hks coilovers(they were too firm for my liking)
This is not a POS GTR, it goes, stops steers better than new original & has no squeeks,squiwls clunks or bangs, it has never let me down & is so nice to drive.
No its not immaculate, its 27 years old, paint presents well, however the rear spoiler has a chip & car has usual light scratches from age & front lower spoiler could do with a touch up & new hardware kit for proper install. Interior is also well maintained with a great dash.
Asking $35K negotiable
Im a motivated seller, however low ballers need not apply
Not interested discussing it here so If you are genuinely interested in the car pick up the phone 0418 896 910 give me a call
More pictures for genuine interested people. (i will have to take them as im not a picture collecter), i know what my car looks & performs like(you gotta pay to play)
Thanks for the AD (SAU)
Regards
Mark
https://www.sau.com.au/forums/topic/467119-sold-1989-bnr32/
Thanks for the bump Carl.
I have had minimal interest in car, i said i was a motivated seller, so i will cut to the chase & drop my price to $30k.
I would rather sell car than store it, i very rarely use it, i have a few other cars & just spent 8 years on a total restoration so i will be enjoying that one now.
I stand by my ad stating this is not a POS gtr its very well sorted & had money spent where it should/needed be & it wont dissapoint.
Anyone interested in new price give me a ring 0418896910 & i can go into alot more detail about it & send any photos you want.
Thanks (sau)
https://www.sau.com.au/forums/topic/467119-sold-1989-bnr32/#findComment-7784601
  • 3 weeks later...
Ok for all who are interested, the car is now sold.
Congratulations to the new owner, enjoy.
Good luck to those wanting a decent gtr.
Thanks SAU for the ad & such a great forum with a wealth of knowledge.
https://www.sau.com.au/forums/topic/467119-sold-1989-bnr32/#findComment-7790086
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
