'93 GTR Freshen up
Hey guys,
Long time lurker.
I'll try condensing the last 18 months into a relatively short post :-)
A friend of mine purchased this car from the east several years ago, I remember seeing it in the flesh and the colour just popped.
When it came up for sale, I jumped on it.
The lads at Galvsport were commissioned to the freshen which ended up being a ground up resto of sorts.
Premise was for a 1000hp street car with manners.  Engineered and insurable.   Carry out the school drop off and have a crack at some motorsport.
Posted Image
Posted Image
Posted Image
Stripped the shell and off for a freshen up of the BMW Boston Green.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  • Like 5
https://www.sau.com.au/forums/topic/467143-93-gtr-freshen-up/
Posted Image
The shopping list as follows.
There will be a bunch of stuff I’ve missed, but you get the idea.
New RB26 Block @ 87mm
GALVSPORT specific block and head machining
HKS Step 2  2.8L
HKS Forged Pistons
HKS Forged Crank (balance, tested, sized and graded)
HKS H Beam Rods
Nismo engine bearings
ARP 2000 Main studs and nuts – Tunnel line bored and main bearings graded
New head comprising
HKS 272 Step 2 Camshafts
HKS Valve springs
HKS Bronze Valve guides
Genuine Nissan Valve stem seals
HKS Cam gears
JUN Cam baffles
Tomei oil restrictor
GALVSPORT head gasket
ARP 2000 head studs
HSE Billet oil pump gears
Modified GALVSPORT oil pump
GALVSPORT head drain
RIPS Extended sump
GALVSPORT extended oil pump pickup
Genuine Nissan  water pump
NSK Timing belt tensioners and idlers
HKS Super fine tune timing belt
Genuine Nissan cam, crank, rear main oil seals
GALVSPORT Billet oil drain flange.
GALVSPORT heater kit
HKS Exhaust manifold gaskets
HKS Intake gaskets.
Precision 6870 Turbocharger, T4 Split rear 0.84
GALVSPORT exhaust manifold
GALVSPORT dump pipe
GALVSPORT intercooler plumbing
GALVSPORT Power Steering reservoir
GALVSPORT Radiator Header tank
GALVSPORT hidden engine loom
GALVSPORT modified cam covers
GALVSPORT Oil/Air separator with scavenge pump to block feed
GALVSPORT Billet Boot plate
GALVSPORT Billet ABS mounts
GALVSPORT hidden brake lines, junction plates, brake lines
Turbo smart 60mm Power Gate
HKS fuel rail – anodized black
ID2000 Injectors with adaptors
R34 GTR Splitfire coils
Nismo Engine and gearbox mount kits
DCS Twin Plate clutch - 1000hp OSG Movement converter
R34 GTR Getrag 6 speed H Pattern gearbox GALVSPORT conversion
R34 GTR Front/Rear crownwheel pinion set, Modified tailshaft, modified half shafts
Radium Auto twin pump surge tank
Walboro 450 E85 pumps x2
Walboro 255 Lift pump
Koyo Radiator
BRIDE seat rails BNR32 left & right
Defi Adavnce BF Oil Temp
Defi Advance BF Water Temp
Defi Advance BF Exhaust Temp
Defi Advance BF Fuel Pressure
Defi Advance BF Oil Pressure
Defi Advance ZD Meter
Defi Advance Control Unit
Defi Advance BF Boost Amber
Defi Advance 80mm Tacho with Red Shift light
BRIDE Stradia 2 - Low Cushion *Carbon Aramid*
LOW MAX - Gradation *Black Logo*
Nardi Deep Corn 350mm *Red Stitch / Suede*
HKB Boss Kit
Glovebox relocated climate control unit
Custom Dash binnacle
Rays Nismo LMGT4 18x9.5 +12 Omori Edition
ANDRA/CAMS compliant bolt in roll cage
HKS Silent High Power Cat Back exhaust
Full Race ETS Pro 4WD controller
Hicas lockout bar
Link G4+ ECU
Honeywell sensor trigger kits
MAC 3 port boost solenoid
FLEX fuel sensor
Abflug Carbon Under Lip Diffuser
Top Secret Carbon Rear Diffuser
Karbonetic Carbon OEM rear wing (Boston green clear coat)
Carbon N1 boot lip (Boston green clear coat)
Garage Defend GT Carbon Cooling Panel
Fujiruma Rocket Dancer Carbon Flap Wing Blade
Varis Japan Carbon Bonnet (Boston green clear coat)
Cree LED H4 & H3 headlights
Zled tail light conversion
BC Racing ZR Coilovers – External Reservoir – F/10kg R/8kg
BC Racing adjustable front camber plates
Ikeya Formula upper control Arms
R35 Front and rear brembo calipers
AP Racing 396 J hook front discs
AP Racing J hook rears
Endless MX72 pads
Goodridge front and rear lines to suit
GALVSPORT billet dogbones front and rear
GALVSPORT billet hand brake bells
  • Like 6
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
