E85 on BNR34 with standard fuel lines...
Hi all,
I was recently told that the fuel lines on BNR34's are actually smaller then BNR32 & BCNR33's... and I know that the ideal setup when running E85 is replacing the standard lines with full braided or Teflon lines, but I wont have the $$$ or time to get that them in time for WTAC in less then a weeks time.
So my question is this, Is anyone running their R34 GT-R on E85 with the standard fuel feed lines???
As im only aiming for around 330-350 kW's at the rears would I still need to upgrade lines?
Cheers,
Glen
Feed and return at the same time drill little holes on the jet pump siphon whatever it's called.
Best to convert to an fittings or use a R33 lid (if it fits.. should I think).
Plugs are different on the R33 lid. R33, S14 and S15 lids all fit but plugs are different haha.
The size of the fuel line itself is not the issue its the fuel hat itself the plastic inlet and outlet are very restrictive.
That being said I you will be able to make the power you are after without touching the hat at all. I made 400awkw or so with a standard hat.
  • Like 2
  • 11 months later...
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
