You might struggle, they are completely different in operation. If you are planning to tune the M35 as a standalone you can just run new wires to the Z33? I would go Z32 or VQ35 personally.
How are you planning to fix the airflow curve if not tuning?
Thanks for the reply Scotty. I bought of Yahoo Japan a series 3 nismo reset ECU which comes with a Z33 AFM and housing along with a patch lead. The plug which matches my sensor has had the wiring and pins ripped out so i dont know how to match it to mine. The system came out of a working nm35 stagea so i presume it will operate correctly on mine. Two wire have been joined on the Z33 wiring harness one of which is an earth.I have power and the sense signal wire but the car wont idol. Any help would be appreciated.
3 hours ago, cad said:
All done Z33 air sensor done and series 3 sports reset seems to be working as it should. Take it for a run tonight and see what happens.
Awesome, keep us up to date. While they're not tune-able, its still interesting to see what it does and it has to be good.
  • 2 months later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
