JBonDSS Posted October 9, 2016 Share Posted October 9, 2016 3x2 bolt pattern driveshafts what cars did they come in,I got the diff and shaft out of an s15I need another set as I have just broken a passenger side inner, test running my project car What stores do people recommend I contact? (Melb - central vic)Cheers James Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/ Share on other sites More sharing options...
GTSBoy Posted October 9, 2016 Share Posted October 9, 2016 They came in S chassis cars and the NA versions of R chassis cars. And probably also in A series cars (Cefiros) and similar stuff that was a mix of the S and R chassis cars. ALL S chassis cars have them. ALL turbo R chassis cars are 5 bolt (unless GTR, then big 6 bolt). Go see a CV reconditioner. They are just a shitty tripod CV joint. I'm having mine done next week (for a similar reason). Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/#findComment-7782272 Share on other sites More sharing options...
JBonDSS Posted October 9, 2016 Author Share Posted October 9, 2016 Thanks for that mate, had the pass side gain massive amount of toe out on a test run , so I think it got pulled to its max outward travel, smashing its way out of the tripod holder,Are s14 shafts the same length and out splines as s15. Just checking my options when I start ringing around tomorrow Cheers Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/#findComment-7782277 Share on other sites More sharing options...
GTSBoy Posted October 9, 2016 Share Posted October 9, 2016 Ahhh....lengths may be a bit of an issue. I cannot tell you. The later cars (say R33 vs R32) are a bit wider in the rear, but I honestly do not know how much variation there is between shaft lengths amongst all these. FWIW, I have S14 shafts in my R32. Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/#findComment-7782280 Share on other sites More sharing options...
JBonDSS Posted October 9, 2016 Author Share Posted October 9, 2016 No worries at all, I'll get s15 shafts again, had a look around don't seem rare Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/#findComment-7782285 Share on other sites More sharing options...
KiwiRS4T Posted October 9, 2016 Share Posted October 9, 2016 All Stageas except the RS260 have 3x 2 bolt pattern...but lengths may vary. 1 Link to comment https://www.sau.com.au/forums/topic/467169-driveshafts-query-3x2-bolt/#findComment-7782371 Share on other sites More sharing options...
