Hey, got this problem, I'm not getting full boost (18psi) in first gear, only getting 15psi. When I switch it to low boost (15psi) I only get around 12psi in first gear. I can hear the screamer pipe from around 9 psi on the high boost setting.
The wastegate spring is 1 Bar, Ive pressurized the intercooler piping up to 24psi and there are no leaks.
I can't remember if it was like this when I got the car tuned as I don't really drive the car.
Mods:
RB25DET Neo
GTX3071R
Link G4
50mm Turbosmart wastegate
6Boost low mount twinscroll Manifold
Edited by jhjones
 You know that 1 bar is only 14.5psi?  Have you got a boost controller or is boost controlled by the Link via a Mac Valve? I'm not sure that full boost in 1st gear is all that important.
I'd be worried if you can hear the wastegate venting at 9 PSI.  Seems to indicate it's bleeding off too early.
You need to get one of these-
Remove the wastegate from the manifold (so you can see when it starts to open) and then disconnect the vacuum/pressure hose at the engine (so you're including all hose between engine and wastegate which may identify a leak somewhere) and then apply pressure (not vacuum) to the wastegate actuator.  In theory it should not crack open AT ALL until you reach what is supposed to be the wastegate spring pressure.  If it's opening before the target pressure then you either have a weak spring, a leaky diaphragm or a leak in the vacuum/pressure hose.  That's my evaluation anyway!!
Good luck.
Boost control is done by the link using a mac valve.
If there was a leaky diaphragm wouldn't i hear it leaking out the port on the mac valve when i pressurized the intercooler pipping. Same with a leak in the vacuum/pressure hose except i would hear it leaking from the hose.
In the high gears boost shoots up the 15psi then slowly creeps to 18psi. Normal?
Right, bigger turbo and getting full boost in 1st gear doesn't come along because of inertia of the CHRA and available energy on the turbine wheel.
I wouldn't be too worried about getting full boost in 1st gear but more by your creeping issue. What size your gate is ? Which manifold do you use ?
How old is your wastegate, and does it hit the track often?
The wastegate springs get weak over time with continued heat cycling, i had 1 bar gate springs that ended up opening around 6psi due to the heat. This was after a couple of years on the track however.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
