Hey, got this problem, I'm not getting full boost (18psi) in first gear, only getting 15psi. When I switch it to low boost (15psi) I only get around 12psi in first gear. I can hear the screamer pipe from around 9 psi on the high boost setting.
The wastegate spring is 1 Bar, Ive pressurized the intercooler piping up to 24psi and there are no leaks.
I can't remember if it was like this when I got the car tuned as I don't really drive the car.
Mods:
RB25DET Neo
GTX3071R
Link G4
50mm Turbosmart wastegate
6Boost low mount twinscroll Manifold
Edited by jhjones
 You know that 1 bar is only 14.5psi?  Have you got a boost controller or is boost controlled by the Link via a Mac Valve? I'm not sure that full boost in 1st gear is all that important.
I'd be worried if you can hear the wastegate venting at 9 PSI.  Seems to indicate it's bleeding off too early.
You need to get one of these-
Remove the wastegate from the manifold (so you can see when it starts to open) and then disconnect the vacuum/pressure hose at the engine (so you're including all hose between engine and wastegate which may identify a leak somewhere) and then apply pressure (not vacuum) to the wastegate actuator.  In theory it should not crack open AT ALL until you reach what is supposed to be the wastegate spring pressure.  If it's opening before the target pressure then you either have a weak spring, a leaky diaphragm or a leak in the vacuum/pressure hose.  That's my evaluation anyway!!
Good luck.
Boost control is done by the link using a mac valve.
If there was a leaky diaphragm wouldn't i hear it leaking out the port on the mac valve when i pressurized the intercooler pipping. Same with a leak in the vacuum/pressure hose except i would hear it leaking from the hose.
In the high gears boost shoots up the 15psi then slowly creeps to 18psi. Normal?
Right, bigger turbo and getting full boost in 1st gear doesn't come along because of inertia of the CHRA and available energy on the turbine wheel.
I wouldn't be too worried about getting full boost in 1st gear but more by your creeping issue. What size your gate is ? Which manifold do you use ?
How old is your wastegate, and does it hit the track often?
The wastegate springs get weak over time with continued heat cycling, i had 1 bar gate springs that ended up opening around 6psi due to the heat. This was after a couple of years on the track however.
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
