Can anyone give me information, pro and con's about these three different types of Fuel Pressure Regualtors?
Do they all do the same job as well as each other?
The nismo item looks like the stock reg, but with a screw on top, where as the malpassi and sard are more solid, robust units. Would this affect their performance?
I''m just a little confused with these products.
Cheers
Dave :headspin:
https://www.sau.com.au/forums/topic/46722-malpassi-vs-sard-vs-nismo/
I queried between sard and malpassi at gavin woods and his response to malpassi involved some fairly heavy language which I possibly shouldnt repeat in polite company. It wasnt a positive response, put it that way.
I dont actually remember what brand he did reccomended over all, but I know sard was a name that cropped up as a "good" one.
ok thats a technical response slapper... but WHY??
is it because its not a jap brand... is it because it costs 1/3 the price of the Sard?
Gavins reasoning (minus most of the more colourful words) was that the malpassi couldnt maintain its set pressure between full boost and idle, especially after a hard run then quick back off. You would see the malpassi holding full boost fuel reg pressure even at idle, or vice versa (ouch!)
Also the build quality was "shit" and "typical of italian crap" and "I wouldnt even throw one on at my worst enemy". ... Thats not entirely verbatim :)
lol nice.
well thats the sort of info i want. I do know that the malpassi's work as i've used one on a previous car with no drama's, but i just want to justify the $300 odd for a sard or nismo item.
Cheers krawler
thats my other query.
The nismo's look like the stock fuel reg, but with a screw on top (the one i owned did anyway)
How do they go at controlling boost? are they rising rate etc? Their small design makes me abit wary of them...
Look at the nismo one that bolts on. It looks like stock.
All it does is restrict fuel on the return.. how can a different brand really have that much difference?
Skyline-Dave. How can it control boost..? And unless you running enough fuel for 4000HP I can see the small size hurting?
And I would say the Nismo one is all you need.. they have been proven to work. Rising Rate is not always a good thing.. you should use tuning to get the fuel right.
Cheers
Dave  :headspin:
Dave;
I've heard only good things about SARD, and Nismo aren't known for making junk. That said, make sure you need one before you spend the $.
yeah i've got a bigger fuel pump, and injectors will be >660cc i have decided.
I want to make sure i am going to be completed protected on the fuel side of things. Hence asking all the questions. Alot of money is going into My RB30DET and the GT35R will be wound up in boost pressure.. so i want make sure i'll have adequete fueling.
^rising pressure reg. are usually 'band aid' fixes people use to flow a little more then what there injectors can handle with normal fuel pressure... and as most band aid fixed its best to do the job proper and just get bigger injectors
ive also heard similar bad things about the malpassi, and have been recommended the sard over it, reason given was that the malpassi cant hold a steady fuel rail pressure, and well if that is the case, then its a pretty pathetic product really isnt it
i recommend you not even go with the fuel regulator, run stock fuel pressure, and run bigger injectors if your running out of fuel, IMO, if your increasing fuel rail pressure to make up for lack of fuel, then your injectors are too close to 100% duty cycle anyways, and again in that case its a safer option to go with bigger injectors, if you want to be safe, which you say you do
pushing the injectors too hard will increase the chance of something going wrong, your spray patterns are also affected when you push the pressure too high
You can also push some more current through the pump to raise the static pressure....
I think.,
mmm i doubt it will, unless you have a shitty regulator, the pressure is simply a result of the restriction from the pressure regulator and it should accomodate for any extra flow and keep its pressure consistent, although its a common DIY trick to upgrade the wiring to your fuel pump, so you get less voltage drop + more current to the pump, which increases its FLOW, not pressure
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
