Ecu swap
Hi guys I'm trying to swap out a ecu to a r34 ecu and I'm just trying to find a pin out for both ecu's I have the one in the car     is ( 23740 0V301) but I have a ( 23740 AA511 ) need both pin outs as I put the r34 ecu in it starts and runs but a check motor light comes on with the original ecu it dosnt bring the warning light up
https://www.sau.com.au/forums/topic/467244-ecu-swap/
More info needed. What vehicle are you talking about? Is it a Stagea? The OV301 is the second most common of the S1 Stagea. The R34 one you have put in may have had traction control which may be the reason for the check light. If so I believe that you can get rid of it by installing a resistor or something like that. I have attached an R34 pinout chart  which is much the same as the Stagea one. I don't know how the OV301 differs from the more common OV300.
Pinouts R34_ecu.pdf
Pinouts WGC34_Series_1_-_STAGEA_RB25DET_Auto_ECU_ translated.xls
https://www.sau.com.au/forums/topic/467244-ecu-swap/#findComment-7783941
It's a s1 Stagea with a manual conversion and has a rb25det Neo in it I didn't do the install I got it like that .... I have all so got the r34 auto ecu but the guy I got it from says it worked fine when he did a manual conversion in the 34 I have gotten the ecu as I want to get a nistune but I want to sort out the check motor light befor I send it away so I know it works when I get it back
https://www.sau.com.au/forums/topic/467244-ecu-swap/#findComment-7783947
Well have you put it in the car and does it drive ok?
https://www.sau.com.au/forums/topic/467244-ecu-swap/#findComment-7783965
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
