Hey guys,
Really hoping someone has some insight for me. I recently had my R32 GTR serviced. Previously my os88 was running Os Giken LSD oil 80W-250 (I know, crazy thick). The previous owner had been using this in the box for 4 years and never had an issue, I also have not had an issue whilst owning it for the past 6 months. However after a few people's suggestions to use the "correct"oil...I changed it to the OS Giken Dogmeister oil 75W-140.
Since then I have a significant oil leak from the box and every time I select 1st gear the car stalls. The shop told me they put 2.2L in it...I was previously told it only needs 1.8L and thought maybe it's been overfilled and spitting it out. I jacked it up and seems to be leaking from the breather hose but there's oil everywhere so it's hard to pin point.
When the car is cold, I can select 1st gear, once it warms (the box) it will stall as soon as I engage 1st unless I keep the revs up and select it. Once I do this I can cycle through the gears and the car drives completely fine...until I come to a stop, select N then 1st again and it stalls (unless I keep revs up)
Does anyone have an insight or idea what could be going on? I understand the clutch might not be engaging or have an issue but as I said, it all ran perfectly before the gearbox oil change, its baffled me???
Dunno, but if I took my car to a shop to get an oil change, and then got it back and it didn't drive right, I'd take it back and tell them to fix it.
They might have put too much oil so it's pouring out of the breather, then maybe there's a clutch engagement issue? I obviously never driven a sequential, let alone an OS88, so I can't say.
Those are my guesses, good luck!
Im very happy with everything else the shop did. In regards to the oil, we changed the grade and wondering if anyone has insight if this could be the cause. Thanks anyway
Yes it does over flow happens to me, so I made an overflow tank.
also have a look at the clutch slave hoses and make sure there not twisted or kinked.
overflow tank is top left, old plastic bottle did the trick for abit ?
Edited by QUP29
The car hasn't had a leak in 4 years, this all started since I changed the grade of oil to the thinner "supposedly correct" grade for the os88. The fact that it doesn't stall when selecting first when cold says it's ok when the oil is thicker. The new oil is thinner and perhaps when it warms up and thins out, it stalls when engaging first. Trying to work out whether the previous thicker oil was actually better or if something is wrong with my clutch.
What could be wrong with the clutch for this to happen only when the car warms up and the act that it drives absolutely perfectly once I keep revs up and select 1st. I have no issue driving the car and selecting gears after that. Only 1st gear is the issue
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
