Clearing out some spare parts
1. Power fc d jetro to suit r32 r33 gtr comes with hand controller and map sensors good condition $600
2. Ross crank trigger signal conveter part #306001 was wired to power fc. I'm unsure of what other ecu this maybe compatible with $100
3. Sard 800cc injectors removed from r32 gtr with plugs will need new pins only ever used with petrol $250
4. Tomie rb26 sump bafle only used for approx 3000 kms. One rubber trap door is a little twisted may be missing some bolts $80
5. R32 gtr 3.5 inch cat (i think 100 cell) and 3.5 inch decat pipe in good condition both with egt port $200
6. R32 gtr hot side intercooler hard pipe kit (just jap) with hoses and clamps. I purchased this for the cold side only $50
7. R33 series 3 std gear set and sandwich plate brand new. I purchased a new gearbox from just jap and replaced all these parts with an os giken 1-5 gearset $350
8. R33 gtr pull style gearbox front cover brand new with gasket also push style slave cylinder brand new $200
All parts are located at Schofields western sydney feel free to contact me on 0407701876 I'm not always available to check online messages.
Chris
  • 2 months later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
