Unfortunately I need to sell my car. A lot of time and money has gone into getting it the way I wanted but I need to clear some space.
It is a 1994 Nissan Skyline R33 GTS non turbo Manual JDM import. Perfect P plater car.
Odo says around 128***kms but it was converted to manual so the cluster has been changed. Previous owner kept it well serviced and the timing belt hasn't been changed, which leads me to believe the kms are closer to 100k ish.
It has:
18x7.5 wheels with decent tread.
Lowered on King springs.
Added gtst rear sway bar (never had one from factory and really improves rear stiffness)
Roof wing/lip.
Replica GTR spoiler.
Nismo clear indicators.
M-spec front bumper with skirts and pods.
Custom "Nismo" front lip.
Just Jap weather shields.
Hella Supertone horns.
Short shift kit.
Alarm and immobiliser.
Nismo shift knob.
Good condition R32 GTR front seats. No tears which is hard to find.
Nismo front floor mats.
Good condition series 1 steering wheel.
Pod filter enclosure with 50% finished cold air intake (will need to add some piping)
Front and rear strut braces.
X-force dual tip muffler, sounds really good.
Sound system that includes a Kenwood head unit, kicker fronts with tweeters, pioneer 6x9's at the back and a custom made fiberglass sub box that fits into the side of the boot. All running from two amps. Sounds great.
Also has reverse camera and screen.
Replaced front and rear rotors recently. Fronts are slotted with plenty of pad left.
Spares it will come with:
Have some rotors but I don't know what car their for. Do what you like with them.
Original front floor mats.
S14 front calipers (project I never got around to)
Stock springs.
Another stock steering wheel, pretty beat up.
Was planning on doing the timing belt change myself so it'll come with a gates timing belt kit with water pump. Cost a few hundred alone.
THE BAD:
paint is fading on the roof, was going to wrap it black but I don't have the time. Some other dings etc as expected for its age.
The gearbox makes noises...I've been told that it's either the thrust or throw out bearing. Still runs fine and smoothly
Again, timing belt needs to be changed.
Air conditioning needs to be regassed.
Always been regularly serviced by me and my brother (oil, spark plugs etc) hasn't really been driven too much or even too hard as I've been on my L's.
Will come with rego till the end of January but no rwc
Price is $8500 but happy to negotiate
Message me for any info no calls thanks 04254291191476692609619.jpg1476692629457.jpg1476692644342.jpg1476692658552.jpg1476692677083.jpg
https://www.sau.com.au/forums/topic/467277-1994-r33-gts-non-turbo-manual/
  • 2 months later...
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
