Engine dead so turbo setup is for sale. Has done 20,000kms at 8psi, with the very occasional hit at 12-14psi (i can count the no. of times on one hand) and comes complete with:
- Trust TD06SH-20G 10cm^2 Turbo, rated at 420hp
- Trust Type R Wastegate
- Trust Stainless Steel Exhaust Manifold
Manifold and exhaust housing have been ceramic coated, and the compressor cover has been semi polished.
Comes complete with dump pipe and AFM pipe and oil lines. This turbo will bolt straight onto an RB20/25, with the exhaust plumbing up to your cat. Comes with re-written for R32 ECU for GTR injectors and Series II R33 AFM. Can supply GTR injectors and AFM at additional cost.
Need to sell urgently to get the car back on the road, but want to sell as complete kit
Asking $4,100 complete
(GTR injectors & AFM extra $400)
- Also have a std RB20 for sale, 170,000kms minimal blow by, suspected bent inlet valve. No reason to believe a problem exists with the engines bottom end.
Asking $300
https://www.sau.com.au/forums/topic/46728-trust-rb2025-td06-20g-setup/
Price Drop.... for $4150 you get:
- Trust TD06-20G , with ceramic coated exhaust housing (approx $1400)
- Trust Type R wastegate (approx $600)
- Trust stainless manifold, ceramic coated (approx $1300)
- Re-written Jap ECU for GTR Injectors and R33 AFM (approx $500)
- GTR injectors and F33 AFM (aaprox $500)
- Oil lines (approx $150)
- Dump pipe/front pipe (approx $300)
- Filter/AFM to turbo pipe (approx $150)
If you need a front mount i can also supply a HKS Type S cooler complete with clamps/silicon and 120deg bend straight off the throttle body to reduce pipe length/volume and also better clear the high mount turbo. Pipes/IC/BOV (SSQV Monza, 6wks old) for extra $1350
So for $5,500 you get a bolt on kit for an RB20DET that at 1.1 bar should se you around 210-220rwkws and at 1.3-1.4 bar around 230-250rwkws
R33 owners can offer prices for only the parts they want as obviously an R32 ECU etc isnt much good to you , but the manifold and dump etc will still definitely bolt on your RB25
Problem is if i sell just the manifold then im stuck with a turbo, wastegate and dump pipe that arent readily of use to anyone...so i would want very good money for it, ie not a reasonable figure...ready for it $1700.
  aqik33 said:
Got any pics of this stuff??
This is the only photos i have until i go see the car next
The manifold is in top nic, so is the exhaust housing due to the black ceramic coating by Competition Coatings.
The wastegate has a nice soft spring so can run as little as 8psi if you require, or wind it in and run as much boost as you dare :) Wastegate is also in perfect working order.
Happto field ppls reasonabel offers for the turbo, manifold, wastegte and dump pipe
  • 3 weeks later...
Bump, had it dyno'd at 8psi the other day and it made 18?rwkws at 8psi. Didnt have time to do a full tune so left it very conservative tune to get the car back on the road. So to date the turbo still hasnt been stretched or even boosted
  Roy said:
Can guarantee that this turbo setup makes an easy and lazy 210rwkws at only 11-12psi on a std RB20. Free to go for a drive in car with this setup, but will need to be quick as it will be removed from car soon
Roy, will Turbo bolt straight to std man?
Is WG on Dump or Exh Man?
Check PM - Greg.
  • 3 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
