10.67 is pretty impressive for an RB20. What's a quick run down of your engine? There have been a number of decent power RB24's over the years in AUS that I'm sure would have been to the strip but they don't really count do they haha.
RX-7, fully legal street car, slicks, Ford 9", fully adjustable coilovers. I ran this time with a crap reaction time, The car can do low 10's I'm sure.
RB20DET - Stock Internals, Stock headgasket even. No cams, no cam gears, no bullshit, never opened.
- Hy35 Holset
-Tial F38
-GFB Gforce 2 EBC - 25-27PSI
-Nistune (Launch control 5800rpm, could be set higher)
-Custom in-house Intake and Turbo Manifold
-Vibrant intercooler
-GM 75mm Throttle Body
-4"- 3" down pipe, 3" SS exhaust
- 2.5" - 3" intercooler piping
- RC 720CC injectors
- Custom Driveshaft
- RB20DET transmission (On my third, looks like I need a 4th).
List goes on.
I'll see if I can upload a video to youtube at some point. Here's some pictures for now. It was fairly close to lifting the front wheels in first and when hitting second as you can see in the photo. Higher launch control, a bit more power and some suspension tweeks might do it. The cars got some blow by issues now but still runs fine. I think I might make the jump to an RB25 neo as I need the bigger transmission anyway (been through 3 RB20det trans, typically synchros get chewed off within a weekend or you break shift forks).
Edited by rx-line
  • 1 month later...
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
