Tuning the v36
Hey Guys ,
i got my skyline v36 07 and it's my first car I want to tune it and play around with the cars preformance but I am a newbie and lack all knowledge of cars . I  really want to do make the car "rawr" when i drive . It's got enough power for me just want to make it look and sound meaner just looking for some tricks and tips .
thanks guys all advice is much appreciated . Thanks for the responses on the other posts
https://www.sau.com.au/forums/topic/467305-tuning-the-v36/
Look around myg37 for modding options. I personally have Stillen gen 3 intakes, Stillen hfc and a custom dual exhaust with hks legamax mufflers. There's only so much you can do on a NA car, unless you want to go FI
https://www.sau.com.au/forums/topic/467305-tuning-the-v36/#findComment-7787004
Whats up man! I have Done lots of mods to my V36, all that remains is a tune, ( Uprev from america, around 800$ will squeeze about 20-30 KW with supporting mods ) and for me to get forced induction. Everything else I have done Local wise and it looks great! ( in my opinion at least. ) I managed to get 194kw at the wheels before I get it tuned and thats N/A, Should break 230kw at the wheels after I get Uprev.
 Ive done Exhaust, custom Stainless Intake system, Full Avery Wrap, Blacked out headlights, Eibach Prokit Kit suspension, Koya 20" Sf06 Wheels. And a few other cosmetic things.
The Silver Photos are when I got the car from Japan 2 years ago. The Black ones are where its at now, just around 10 grand in mods to change her. Imported at 43,xxx Kilometers, now at 67,000xxx Type SP!
  • Like 1
https://www.sau.com.au/forums/topic/467305-tuning-the-v36/#findComment-7788225
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
