Car stalling while driving with new turbo
hi all,
i just replaced my turbo on my gtt from factory turbo to Garrett gt 30/76 internals on my factory housing.
when i drive at a rpm over 3k and put it in neutral the revs will go all the way down till the engine stops.
does anyone have any idea why this could be ?
thank you
factory pipe work.. could be leak somewhere..
Are you running any wanky BOV? or is everything stock except the turbo?
Also it might be overboosting because the turbo has a larger actuator on it.. not ECU related.
2 hours ago, miskyline94 said:
It's a factory bov but it is blocked of to re-curc and I have a front mount intercooler other than that its stock
there's your problem :)
The pressure is also going through the air flow meter backwards. The ecu sees this as additional air flow and injects more fuel. On some cars with air flow meters this causes stalling problems on others just rich running, unless the ecu has been tuned for it. Try unblocking and see what happens. Im sure dosepipe will correct me if im wrong :banana:
  • Like 1
Also i might add,
the reason i changed the turbo is because the factory one shit itself but when it went out there was a bit of oil around the intake hoses, so i was wondering if some of that oil would have gotten on the AFM.
should i remove it and clean it with contact cleaner? @admS15 @Dose Pipe Sutututu
ok so i there is nothing the bov is doing to the stalling,
but we did rasie the idle a tad so the car has stopped stalling and also must of fixed the over boosting problem.
a new ECU is defs on my list but money wise it is not going to happen very soon.
and whats a nistune board? easy install and pricey? @GTSBoy
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
    • Far out, that thing looks like some loose fun!  Nothing beats the rawness of a filthy old Nissan with zero aids to keep the wheels pointing in the right direction like modern "fast" cars!
    • If there is no ridge at the inner edge of the battery tray (ie the battery tray is flat until it rolls off the edge into the open space of the bay), then no, it won't matter if it overhangs. If the battery would be propped up by any ridge, then that wouldn't be ideal. The bottom of the battery case would not be sharing the load. It would be concentrated on one end edge and a line across the bottom where it contacts the ridge. And possibly it wouldn't fit under the locking clamp either. I only upsized my battery to the max because: I sometime have to leave my car undriven for weeks at a time while I am away for work. On the previous battery (replaced a couple of months ago) I had to leave it undriven for months at a time!! I sometimes abuse the battery by running the stereo up loud for many hours while I wash and polish it. This is how I realised that the previous battery was on its last legs, because it got to the point where it was too weak to start after a couple of such. It was 7 years old though, so, fair play. Supercheap had a good special so the X was only ~$250 instead of ~$320, which seemed sufficiently less painful. I had already been using NS70 for the previous 2 batteries for most of the same reasons as above. The X is just the final boss level. I was contemplating going LiFePO4. But it's like $900 to do that properly, and while you save >10 kg of weight, you can likely only expect a couple of years longer life. So meh. Maybe when the price comes down further. Although, in ~7 years when I have to replace this one, I might not be allowed to drive such an anti-social vehicle anyway.
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
