Hello everyone,
Got a problem that made me pull my hear out, i literally searched whole internet didnt find anything that could help me. So here's what happened: after swaping rb25det neo into my r34, the engine could start just great, after removing the old ECU (rb25de neo) and installing rb25det neo ECU the engine wouldnt start, the starter was rotating it but the fuel didnt go. Checked every fuse and relay all worked perfect.
We put back old ECU but it didnt start even after that. Checked fuel pump wires and electricity was not going there. after rewiring ecu wires and forcing to let the fuel pump work, engine still didnt start not on rb25de neo ECU, nor on turbo ECU.
Please someone help me figure out what the hell wrong there :((((((
https://www.sau.com.au/forums/topic/467344-r34-wont-start-after-swap/
I suggest you take a very close look at the ECU harness connector. (Not the pins on the ECU). If all the pins look ok from the front of the connector then look at the rear end of the connector where the wires come into the connector. You are looking for wires that may have been pushed back too far out of the connector. They would be sticking back further than others.
If you see nothing unusual in the connector then look at the ECU pins on the ECU itself.
If all ok again then do basic checks for Injectors firing, Fuel pump going. Spark at the spark plug. Also check that fuel hoses are around the right way by disconnecting the pipe from the filter outlet and catching the fuel in a can while someone cranks the engine for a few seconds.
Michael.
  • 8 years later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
