Injector duty cycle to calculate rough power figure VS actual Dyno graph
So, might seem like a dumb question. I know there is a formula for it... Just not sure which is correct. or the math....
If I am seeing a max injector duty cycle of 82% on 700cc injectors (Rb26 - base fuel pressure), in theory, can you compare this calculated HP figure to that of what the Dyno reads out?
Would i say that 1cc = 1HP, so 0.82% of 700CC = 574HP
Is that fairly accurate?
# never was good at math's
Edited by djvoodoo
Engine horsepower, yes.  Not chassis dyno horsepower.
FI cars run richer so you may not get quite as much as 1HP per CC.  But good enough for estimating injector requirements.  Maybe slightly less reliable for what you're asking about.
So give or take, we'll say 82% duty cycle on 700cc is roughly 520-550 engine HP. At the wheels you'd be looking at mabee 420ish (or about 315rwkw)
More to the point - What if the dyno reads quite low compared to what you are seeing max injector wise? Can they be compared? I'm guessing fuelling and how much fuel is dialled in at the top end is also a factor which can skew duty?. Lets just say i'm running about 11.5 to 11.8 in the top end AFR's.
In more just curious at how many different ways you can calculate wheel HP other than just a dyno number.
I always thought it was 5cc of fuel was required per horse power, so a 550cc injector is good for 110hp per cylinder then multiplied by 6 cylinders was 660hp then times it by .8 if you want to only use 80% duty cycle is 528hp
There is never going to be an exact science but obviously there has to be something close otherwise picking the correct injector would be s stab in the dark
The fairly rough rule, particularly true for RBs, at least RB26s, is that (given 6 injectors) then the cc size of a single injector is the maximum engine power supported by those injectors.  Factory 440cc injectors will run up to about 440HP.  Plus or minus the usual range of variables of course.  It's rough but good enough.
yes rough rule for approximating the size of injector you need.. but the OP wants to determine how much power his car is making based on injector DC.. that's obsurd.. just as obsurd as a moron on a Facebook page telling someone to install a resistor pack on their high impednace injectors because their car won't crank over.
You can actually do a better job if you can measure the airflow rather than the fuel flow.  Do you have afm's? If you can convert the voltage to a flow you can google any number of calculators to convert the air flow to rwhp or engine hp or whatever.
I'm using MAP sensor. May as well do a data log session on the Vipec and look at air flow.
you want to work out power, drag strip.
x weight can going so y speed in z time and k distance (factor in some basic air drag) - that is much more accurate then working out how much power a motor makes based on air flow and fuel usage.
You need to remember a motor is not 100% efficient, and x air/fuel does not equate to a direct 100% energy transfer to mechanical energy - there are losses such as heat due to inefficiencies.
Certainly will do bud. Just have to work out when!!!
The correlation between air flow and horsepower is much closer than that between terminal speed and horsepower.  You don't, for example need to compensate for such minor things as drag coefficients, frontal area, gear change, traction, engine torque characteristics etc etc.
+1.  And again, anything you use to estimate "power" is going to be "estimated engine horsepower", not hp @ wheels - and I know from experience that often the calculated results often get heavily question because by nature of how crazy low Oz dynos read the crank hp results which get calculated if done correctly are often much higher than people expect from typical @ wheels readings on a Dyno Dynamics.
A thing no one has mentioned here is fuel as well, if you treat the % duty cycle of x size injector = hp described above for 6 cylinder turbos and are running E85 you will get very optimistic results :)
  • Like 1
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
