Drag Rear end set ups
Hey all
Im looking at changing the rear end of my r33 gtst. runs about 400kws at the wheels. im struggling to get any traction even on a well prepped strip and slicks.
Below is a video, if you turn the sound up you can hear im on and off throttle the whole time and spinning/loosing traction the whole time.
At the moment it just has a welded diff and lower springs with soft shocks,
What can i do to sort this??
video-1477097823.mp4
https://www.sau.com.au/forums/topic/467406-drag-rear-end-set-ups/
  • 3 weeks later...
A strut/spring setup in the rear with quick/light compression and slow rebound will allow the car to squat and transfer more weight over the rear wheels. I woudl think the front would have a stiffer spring with high rebound in contract.
This is what I can gather however.
I can't tell if you have slicks or not but I went from 1.7's to 1.5's in just learning to use them properly (proper burnout heat). Also doing your burnouts in the water box will coat your wheel wells in water and when you get to the line and stage it drips down on the tires! This is bad.
Also slipping the clutch off the line will cause you to get off the line super quick and without spinning tires if done right. Really a hard thing to master.
Do you have launch control? what RPM are you leaving at? What tires are you running>?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
