Sau Vic Go Karts 2016 Round 3
14611004_10155351553769386_8138282252620
December 9th is the date set for the final round of the SAU Vic 2016 Go Kart Series.
To be held at Auscarts Racing at Port Melbourne this final round should prove exciting and a challenge for everyone!!!
https://www.google.com.au/maps/place/Auscarts+Racing/@-37.8324332,144.9244323,15z/data=!4m5!3m4!1s0x0:0x8d522baf771189a0!8m2!3d-37.8324332!4d144.9244323
The round will consist of
Qualifying session - 10min per group
Heats - 10min per group
Consolation Final - 6mins
Grand Final - 6mins
Kart Info -
European built Sodi kart, 9 horsepower, 4 stroke, 270CC, powered by a Honda engine, up to 80km/h
Track Info -
The Port Melbourne Setting is fitted out with a  State of the Art Track. Auscarts always meets high standards by constructing a purpose built racing circuit featuring grading, sunken corners, A Pit Lane Bridge, three long straights, fast sweepers, two tight and two wider hair pins, two switch backs and much much more.
Entry Info -
Entry fee is $85 which includes all race sessions
Sign in at 7pm, racing starts 7:30pm
Drinks and snacks available from the venue.
To enter simply send paypal payment to - [email protected] with the reference GK-R3
- Drivers List -
Melissa Thornton
Matthew Doyle
Sam Lehmann
Jayden Ingley
Mick Godden
Mitchell Carlesso
Liam Clements
Daniella Daniels
Vince Tomasello
Simon Henman
Haider Butt
https://www.sau.com.au/forums/topic/467415-sau-vic-go-karts-2016-round-3/
If you're looking for something to do tonight we still have a few spots left for tonight's round. Get in touch here if you would like to race or first in tonight gets on the grid!
A few more names have been added to the driver's list too so check out the top post for a who's who of SAU Vic karting!!! :)
What an awesome night of racing!!! Big thanks of course to everyone who came tonight to either watch or to get out there racing!
Congrats to the racers who ended the championship on the podium. Championship standings ended as 3rd Sam Lehmann, 2nd Matthew Doyle and our 1st place winner for the 2016 championship is - Daniella Daniels. (full championship results will be posted soon). Great racing by all and close times between people made this year very entertaining to watch.
We hope you had a heap of fun over the championship and that we will see you for a bigger and better season next year.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
