Did I install my pod filter correctly?
Hi, I've just done my first ever mod on a car (a little one, but still lol). But seeing as its my first mod I want to make sure that its done correctly.. or at least good enough.
So I read a few posts and it seems like the hose that runs parallel to the airbox isn't important? so I just unplugged it up near the top of the engine (pic 3)
Is it fine to leave it like that? or should I have done something else?
Also I've only ziptied the pod filter because it was really floppy.
Thanks
I think that was my first mod too but wasn't the last. I left the hose in place and plugged the end with a bolt. If your filter is attached with a plastic adaptor watch out that it doesn't crack with the movement. I had to replace plastic adaptors twice and it's hard to spot the cracks at the join but means it would leak unfiltered air into the engine. I got an alloy adaptor in the end which was hard to find for the 3 inch adaptor neck that I've got but an Impreza one had the same bolt hole pattern.
  • Like 1
I'll be sure to check that it doesn't crack... I'll look into getting an alloy one. Thanks.
Nothing screams defect me more than a bright blue pod filter cable tied up to a bracket.. lol.. - You'll probably want to cap off that line you took off up near the back of the inlet plenum, it'll be a vac leak and you might notice a high idle etc
And keep your stock airbox, for when you do get defected you can get it cleared! :)
  • Like 1
And keep your stock airbox, for when you do get defected you can get it cleared! [emoji4]
What's defect? Is that some sort of legal trouble? In New Zealand I'm pretty sure it's fine to have a pod filter *I think*.
Should I put that hose back in and just put a screw into the end of it?
I'll for sure keep the stock air box though :P
He's in NZ, apparently they are a lot more relaxed.
Hilarious, Reminds me of the first 'mod' i did on my very first car..........one day hopefully you will think back to this and find it as amusing as i'm finding it now.
Like others have said, there is really no need to remove your stock airbox, if you must keep the pod get rid of those cable ties! I wouldn't expect them to last long anyway, fashion up a bracket, not hard and can be done with minimal tools that will hold it much more securely.
But how will you pick up girls at car parks with a stock airbox? :P
Actually, my "intake mod" was chopping the airbox on my R31, made a soft "prr" noise on decel and dirtied the filter quicker. Putting better tyres + brakes + suspension were much, much more effective.
14 hours ago, colourclassic said:
Some of your must fap into your 'stock airbox' judging by the responses.
I'd glady sacrifice 5kw for more turbo harmonics.
Shame yours isn't turbo though.
What's so harmonical with putting a pod on a stock turbo and engine?
Just make a bracket for it using a $6 piece of metal from bunnings. All you need to do is measure the distance between the pod clamps and bolt holding the power steering resvoir and bend into shape accordingly so that the bracket fits under the clamp and bolts into the same hole as the resvoir. Better than cable ties.
Or just put the factory airbox back. There's a 9 second skyline r33 on youtube that runs a factory airbox (mind you its slightly modified).
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
