EOI Trade - 290kw JZS147 aristo 2JZ for GTR 32/33
Wanting to trade my single turbo JZS147 aristo for a lightly modified R32/R33 gtr in Sydney. Or even sell outright if someone is interested.
Not massively fussed on colour, just a clean body with no rust & light modifications is mainly what I'm after, only wanting a weekend street car for now, as the aristo has been for a few years.
Reason for trade is i have no need for the big 4 door, i miss driving manual as my daily is also an auto, & all my spare bits & pieces are for an RB26, not so good for a 2jz.
Quick specs list:
* 1995 S2 in black with leather interior & factory sunroof, factory LSD, cruise control
* Rego valid until September 2017
* shift-kitted auto gearbox with trans cooler & factory converter
* 2JZ with single Garrett GT3582 turbo making 286kw at the wheels on 18psi
* Apexi Super AFC piggyback on standard ECU
Turbosmart eboost street boost controller (set to 15psi low & 18psi high boost)
19" work meisters
Veilside twin 3" exhaust
* adjustable fuel pressure reg with gauge in engine bay
* I'm sure there's a whole lot more I've forgotten here
Plenty of work done, this is a quick car even for its weight & size. Traction control is there for a reason. I've had this car for the past 3 years now, had a lot of maintenance & servicing work carried out to bring the car back up to a reliable level:
* radiator replaced approx 12 months ago
* lots of seals replaced as it was leaking oil in a few places (no longer), these include front & rear mains
* turbosmart 40mm external wastegate installed & plumbed back into exhaust - approx 12 months old
* turbosmart bov fully plumbed back - approx 12 months old
* Apexi Super AFC & Turbosmart eboost installed as part of upgrade works roughly 12 months ago
Car value is being listed at $13K neg, I have roughly 10K in receipts alone for work carried out in the past 2 years. I can add cash on top for a tidy GTR up to a certain point, or I also have a road bike which I can throw in to increase the value on my side.
Please PM me on here, or msg 0407 896 339 for further info, questions or offers.
Cheers, Chris
also would be interested in RS260 stagea, or possibly even GTR with blown engine
throw me some offers, worst i can say is id rather keep this beast
BUMP
possibly also keen on an RB25/26 powered cefiro / laurel or R32 GTS-T, maybe even an r33 or r34 for a swap closer to same value
throw me some offers & see what catches my attention
  • 1 month later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
