Hey guys,
My car is currently making 410awkw (on pump) with my RB28, os88 box and "ACE twin plate clutch"
The clutch pressure plates have failed somehow and are getting stuck (took ages to pry then out)
So I'm in need of a new clutch ASAP and would like suggestions please. Once the clutch is in, I'm going e85, turning up the boost and aiming for the 500awkw mark. I will certainly need a clutch to hand this.
My car is set up for circuit and that's basically it sole purpose, street driven maybe once a fortnight and I may give it a run down the quarter so I'd like suggestions based on that please.
I know nothing about clutches and there are so many and mixed reviews but usually on lower HP setups, so help with my power would be greatly appreciated
Have you sorted a clutch out mate?  May have what you need... 7.25" Quarter Master pro Triple Plate.. All plates are brand New. Comes with Flywheel to suit. Was too aggressive for everyday driver. PM me if interested.
Hi mate, I've sent it back to NPC for a rebuild. I really liked it, twin plate, no rattle and super easy to drive. Pressure plates were stuck good, took forever to pry them apart, hope it can be fixed instead of needing replacement
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
