Engine Carbon Clean?
Hi,
My daily ride is a Subaru.  Dealership and the local mechanic do the good 'ol "tune up in a can" and spray the upper cylinder cleaner in then out the exhaust is a black haze of built up carbon deposits.  I'm wary of miracle cans (besides WD40) but enter Engine Carbon Clean.  Doing some digging, they started in the UK and have spread their wings to VIC.  Can't find a bad review, but can find before/after on same day dyno runs and the results look good.
I'm thinking about rolling the dice and giving it a crack on the GTR.  Thought I'd throw it out there, anyone done this or similar before?
Cheers!
https://www.sau.com.au/forums/topic/467478-engine-carbon-clean/
Always a bit wary of these products:
1.  Why is your engine so gunked up it needs this stuff, better addressing the issue?
2. If its a new rebuild and its done right then you shouldn't need it anyway.
3. If its an older motor and you use it the chances are you will remove the carbon that the motor has come to rely - the results could be worse performance/reliability.
4. What end result do you hope to get out of doing it?  is it worth it?
5. How often do you intend doing it?  Every 5K, 10K etc?
Maybe if you purchased a low mileage car driven by granma to bingo [where the oil never ever got warm], and it needed a fresh start in life, but otherwise I can't see the benefit.
when i had the head off recently replacing head gasket, i used the liqi-moly carbon cleaner to get rid of the carbon buildup on top of the pistons (rb25det). It worked well, in that it really dissolved it, but even then some small spots took heaps, letting it sit, and then some scrubbing to get them removed completely. Pistons looked great afterwards though. So not sure how much carbon these products would remove if just sprayed into the intake, doesn't seem they would remove the really caked on stuff...and don't know how long it would take before it builds up again?
.... So not sure how much carbon these products would remove if just sprayed into the intake, doesn't seem they would remove the really caked on stuff...and don't know how long it would take before it builds up again?
The Subaru can spray is part of a regular service. Spray and idle I believe. AFAIK the Engine Carbon Clean mob take 30+ minutes to finish up the job. I'm waiting for a call back and I'm going to ask a stack of questions.
Keep in mind all those euros and the VQ carbon build up thread are all for direct injection motors. They get heaps of build-up in the intake side, unlike regular fuel injected motors. So their power "gains" are going to be much more significant than yours.
  • Like 1
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
