Hey all,
Just got the head for my rb25det neo back from being ported and reconditioned..
I have noticed the front intake cap appears to have been damaged in transit.
It is not perfectly round where the seal sits, there is also 2 small cracks, 1 where the seal sits and another on the top surface.
I understand these caps cannot be replaced without getting the head linebored.
Would this cap be OK to reused considering there is no damage to the surface that sits on the cam?
I have emailed the company that reco and ported my head but won't get a response till next week..
If I was to try and recoupe my losses through the transport company it will likely take a long time and I may still be down $$$ to get a new head or get this repairedc9b27bd305a80b789e5cdb4cb20aba22.jpg158cd4a0c7ecb9fcf932258cd668858a.jpge35260a8a0e3d59daecf7c9318a2b4ae.jpg
https://www.sau.com.au/forums/topic/467499-damaged-cam-cap-on-fresh-head/
Better off not to dodgy up that damaged cap.
You can find a cap off another head and fit it without necessarily needing a line bore. It needs to be dummied up, measured and checked that the cap sits concentric with the bottom. You would want to get the engine re conditioner to do this because they will have the measuring equipment required. I've done this in the past with success after a cap mysteriously went missing. The heads would be machined with good enough consistency in the factory that a lot of caps could possibly be interchanged between heads.
Thanks mate, I'm pretty pissed off at this point just seems to be one thing after another. I will have to wait until Monday to get a response from the machining shop but hoping they had some sort of insurance on the freight.. if a cam cap cannot be sourced is having them line bored a practise that has been done before and would it be a very cost effective repair?
Not sure on the line bore because i've never had to do it. You'll find out from the workshop once the easier options have been exhausted i guess. Put out a wanted to buy and see if people have got any old heads laying around to pinch their caps.
Just by chance I may have one floating around in the garage at my mum's house. I'll let you know by Monday.
I'm running with an other cap that the one the head came with. Two trackdays and some km on the roads and no signs of wear on the cam nor the cap so you can use another cap if needded.
This cap is not extremely loaded because the timing belt is pulling the cam downward and all the efforts of the springs on the 1st cylinder are handed by the 2nd cam journal. This one is really just the support for the cam seal.
And the fact that these cracks are black inside mean that they are there since a while, you just didn't noticed them before I think.
Did you ream or linebore the head, or meaure it when you put the other cap on?
It was definitely not damaged before, it would have been picked up by myself or definitely by the machine shop, and there was another mark on the front of the head where it looks to have been dropped.
Regardless the head is back off and packaged up to be sent away on Monday..
Nope and nope.
I fitted the cap without the cam to "check" the alignement visually but didn't measured it nor linebored it. As it sat flush with the head I just installed the cam and tested it but checked it twice since the installation (after each trackday) and nothing to report, it work as it should.
Do you think that the head fell off on the cam cap during transport ? The box where the head came in should show some trace of this shock. Anyway this will take time to get it repaired. Given its position I wouldn't mind using an other cam cap, doing it in the middle of the cam where the cap is taking effort from the spring is another story and may need a linebore. But this one is "replaceable" to me as it is not as critical for the cam function, it's there more for sealing purpose.
I understand what your saying about the front cap having no load on it, but its off already and the risk is too great..
I didn't really preserve the box for inspection when I unpacked the head, but I am sure it has been dropped. I got the head back 4 weeks ago but it has been sitting boxed up on the shelf waiting to be installed, If that Is enough time for the cracks to turn black.
There was no insurance on the freight and I expect I will have to cop the full cost of it myself
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
