On 11/1/2016 at 1:30 PM, jhjones said:
No
Can you confirm if the little canister on the front is the same? Is that the receiver dryer?
I've been offered a new model condenser and Amayama says they are interchangeable but the lines look different.
Edited by ActionDan
https://www.sau.com.au/forums/topic/467514-r34-condenser/#findComment-7789517
  • 3 weeks later...
Hey Dan, did you figure this out?  I'm actually trying to source one too...
From what I've found out, i think there's actually 3 models of condenser
Nengun list two -
92110-AA002: Nissan - Skyline - R34 GTR - BNR34 (May/98-Jan/99) - A/C Condenser
92110-AA401: Nissan - Skyline - R34 GTR - BNR34 (Jan/99~) - A/C Condenser
I believe that there is also 92110-AA400 which is what Amayama says is interchangeable... but then RHD Japan also list the two different parts as:
Part Num: 92110-AA400 : 99/1 ~ 99/4
Part Num: 92110-AA401 : 99/4 ~
So, my problem is I'm pretty sure my car was a 99/4 produced car, so I'm really not sure exactly which one i need!  I've pulled the old one out and it looks like this
https://goo.gl/photos/a3TNQ7p2mgw8WFY59
I'm pretty close to just ordering one through RHDJapan - pity you're not in Sydney, maybe we could have got them shipped together!
https://www.sau.com.au/forums/topic/467514-r34-condenser/#findComment-7794205
Get it through Amayama, they're cheaper.
I got one from Eribisu, Andrew Hawkins GTR.
It's a black one, mine was silver like yours and it went straight in.
They are all interchangeable it seems.
This condenser came with black lines from the core to the compressor and into the cabin, but they're identical to mine and a pain to swap unless you're already doing a turbo swap.
https://www.sau.com.au/forums/topic/467514-r34-condenser/#findComment-7794215
  • 1 month later...
On 11/1/2016 at 9:07 AM, jhjones said:
theres two different part numbers for the GTR. Whats you chassis number?
92110-AA400- (9901-9904)
92110-AA401- (9904+)
My VIN is BNR34-004312 , Can you check for me as well?
Part No. A/C Condenser
Part No. Receiver-Driers
https://www.sau.com.au/forums/topic/467514-r34-condenser/#findComment-7804728
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
