21 hours ago, Hadouken said:
Wow. You're in your 30's and complaining about the gtr being uncomfortable?
Soft man, soft.
*Looks at the suspension in the car...*
I see the issue here. :D
  • Like 1
Josh said:
With a lovely chassis like the 34 with some decent rubber and power, the valving performance offered with the X-R series I feel would be ideal.
The Blue series are an excellent package for the price point but are a street/comfort orientated style setup that when using your car for even spirited street driving may not offer the support needed with your level of rubber and the AWD. Blue series are $1590 inc GST and come with default spring rates of 9kg front and 3.5kg rear.
The difference between the X-R and X-C is all in the valving, this determines how a shock works and gives it its characteristics. The X-C series are developed for comfort and ride quality only, so again I feel if wanting to exploit your chassis and power this would be a little lacking compared to the X-R series.
The X-R series paired with the spring rates recommended are aimed at being the best blend between performance and ride quality with only our custom valved Red series offering a better blend.
Nah, get the Blue and tell them street use ;).
Massive difference between my TEIN and Ohlins (all second hand), Ohlins are "street" setup and valved/sprung softer, so driving around is much nicer.
TEIN and current HKS suspension can get airborn, Ohlins rode over them quite nicely (for a short stroke damper).
Would be even better with the "better" R34 chassis. But then I don't know how smooth your roads are compared to Sydney.
A mate bought some Blue for his Evo8, probably more comfortable than the stockers.
On 10/29/2016 at 11:15 PM, Terry_GT-R34 said:
Post-2011 ISF
Magnificent low Km "IS-F" at Earlwood/Sydney. Silver.
I've driven this one, and it's nowhere in the 90s..., or 80s..., or 70s...
You can contact God_speed here on SAU
1 hour ago, ActionDan said:
What was your take on it Terry?
* Response is immediate without hesitation
* I never used the brakes in quick succession to detect any fade
* Cornering is really good whilst having driven M3s before. Good tyres on the car help of course.
* Power curve through the gears is strong and seamless
* Steering has good feel but it's not as connected compared to a GTR of course.
* Comparable certainly with any  M3 I've driven. So whilst it's a buyers market especially for the next 10 weeks, try it out. when you plant your foot down, the V8 sound is sublime .
  • Like 1
  • 3 weeks later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
