21 hours ago, Hadouken said:
Wow. You're in your 30's and complaining about the gtr being uncomfortable?
Soft man, soft.
*Looks at the suspension in the car...*
I see the issue here. :D
  • Like 1
Josh said:
With a lovely chassis like the 34 with some decent rubber and power, the valving performance offered with the X-R series I feel would be ideal.
The Blue series are an excellent package for the price point but are a street/comfort orientated style setup that when using your car for even spirited street driving may not offer the support needed with your level of rubber and the AWD. Blue series are $1590 inc GST and come with default spring rates of 9kg front and 3.5kg rear.
The difference between the X-R and X-C is all in the valving, this determines how a shock works and gives it its characteristics. The X-C series are developed for comfort and ride quality only, so again I feel if wanting to exploit your chassis and power this would be a little lacking compared to the X-R series.
The X-R series paired with the spring rates recommended are aimed at being the best blend between performance and ride quality with only our custom valved Red series offering a better blend.
Nah, get the Blue and tell them street use ;).
Massive difference between my TEIN and Ohlins (all second hand), Ohlins are "street" setup and valved/sprung softer, so driving around is much nicer.
TEIN and current HKS suspension can get airborn, Ohlins rode over them quite nicely (for a short stroke damper).
Would be even better with the "better" R34 chassis. But then I don't know how smooth your roads are compared to Sydney.
A mate bought some Blue for his Evo8, probably more comfortable than the stockers.
On 10/29/2016 at 11:15 PM, Terry_GT-R34 said:
Post-2011 ISF
Magnificent low Km "IS-F" at Earlwood/Sydney. Silver.
I've driven this one, and it's nowhere in the 90s..., or 80s..., or 70s...
You can contact God_speed here on SAU
1 hour ago, ActionDan said:
What was your take on it Terry?
* Response is immediate without hesitation
* I never used the brakes in quick succession to detect any fade
* Cornering is really good whilst having driven M3s before. Good tyres on the car help of course.
* Power curve through the gears is strong and seamless
* Steering has good feel but it's not as connected compared to a GTR of course.
* Comparable certainly with any  M3 I've driven. So whilst it's a buyers market especially for the next 10 weeks, try it out. when you plant your foot down, the V8 sound is sublime .
  • Like 1
  • 3 weeks later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
