COOLANT LEAKING R34 GTT
So I realise this when my oil temperature went up half way about 110 degrees on a normal drive, came home after half an hour of driving and turned off the engine and check the engine and it was literally boiling you can hear it!! Next morning I went to check the coolant in the radiator and it was GONE, I thought I blew the head gasket!! I poured about 4 litres off coolant and it was back to normal but then I realise there's coolant leaking where my water pump is, I'm not certain it's the water pump but it's all around that area, and it drips down to where my oil sump is what do you guys think and it's not little drips, I turn the car on and it drips a nice puddle in less than a minute :0 I checked my oil and there's no milky or any smoke from exhaust, just a leak, could be thermos housing but the leaks looks more above it
thing is my mechanic replaced the water pump, and whole timing kit and also my 3 belt just 1 month ago. So it's still new !
Heres some pictures
https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/
From the looks of it, the Water pump looks good still, touched it and felt no wetness. I'm thinking i must've destroyed my Head gasket and its leaking from there :S
Which im hoping thats not the Case !
P.s When i got the car back from mechanics which was exactly 3 weeks ago, the car was fine no leaks nothing.
Then just 2 days ago on the way home from going out, My Oil gauge in the center console went to the middle which is not normal for me. and the ENGINE LIGHT CAME ON :O !
Then next thing you know, I got no coolant in the Radiator and no coolant in the Reservoir Bottle. And knowing i drove it without any WATER OR COOLANT whatsoever
I must've busted the whole leak Bigger cause now when i start the engine not even for a minute you can see the coolant leaking from somewhere at the engine zz
I should never have got this car :( Had way too many problems one after another due to previous owner not taking care of it.
Major service i have done before this Leak happen: (Just 3 weeks ago so everything is still new)
Timing Belt Kit (Idler Puller & Tension)
Replace 3 V-Belts (Alternator, AirCon, PowerSteering)
New Water Pump with gasket Replaced !
Valve Cover Gasket ( Rocket Cover )
Thermostat Replaced
This was all done professionally at a Mechanic who specialists In SKYLINE AND MANY JAP SPORT CARS
so no dodgy job here.
Edited by Jonic
It is almost certainly a problem with the water pump install, so take it back and get them to look at it.
Other possibilities for loosing all water are a split hose somewhere (which may have been disturbed during the timing belt change, but that's not really their fault). It won't be a head gasket leak, they won't happen externally (ie they will either leak into the cylinder then exhaust, or into the oil).
If your mechanic is within a couple of minutes of home just drive it there, the engine will take at least 5 min to get hot without coolant. Keep an eye on the oil temp and stop driving if it gets to normal temp. Otherwise give the mechanic a call and ask them how to get it back to them, since it is likely to be their error.
Before you do this, just check your radiator top and bottom hoses are connected, and hose clamps are tight.  Also check your hoses for leaks and splits.  Also just check that its not your radiator leaking somewhere as well.  Even removing the stone tray and seeing where the leak comes from?  I agree that the likely culprit is the water pump, but a quick check of the simple things might be a smart move before 'firing from the hip'.
  • Like 2
So I took it back to the mechanic and it is the Water Pump, the weep hole was where it was leaking from ! It only got changed 1000kms ago so here's the deal guys, DO NOT BUY REPCO WATER PUMP FOR HIGH PERFORMANCE CARS, it will bust on you ! So need to replace the water pump since it's gone now ! Getting a genuine one from Nissan to be safe!
That's actually quite interesting to hear. Glad your had your problem sorted.
It was a rb25det engine, r34 GTT, I only went a little hard a few times after I got it majorly Service (haven't even RED line it yet, how sad) and after a week of driving, next thing you know there was no coolant left and the car over heated bad. I was like wtf seriously !?
Nissan water pumps are cheap enough, $150-$200 is nothing when it should last for 100,000km (ish)
I'm fairly sure I've heard of bad reports of repco water pumps before, not that it helps you now but good lesson for others
  • Like 1
On 11/2/2016 at 2:40 PM, Jonic said:
I purchase the water pump so all goods they can pay me back including labour cause yeah not my fault it was faulty after less than 2 weeks of it getting replaced :)
So are repco covering all your costs? Or is that yet to be seen?
On ‎2‎/‎11‎/‎2016 at 8:43 PM, tridentt150v said:
Out of interest, was it an RB25 one or an RB30 one?
No, I meant the water pump itself, they are slightly different and REPCO and others often carry the one for the RB30, but rarely stock the proper one for the RB25.
  • 1 month later...
It's funny cause before I change the water pump the check engine light came on, I'm assuming it's the coolant temperature sensor Acting up when I had no coolant. Now the car is running on a Limp mode how sad. Too many problems with this R34 >.>
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
