Jonic Posted October 31, 2016 Share Posted October 31, 2016 COOLANT LEAKING R34 GTT So I realise this when my oil temperature went up half way about 110 degrees on a normal drive, came home after half an hour of driving and turned off the engine and check the engine and it was literally boiling you can hear it!! Next morning I went to check the coolant in the radiator and it was GONE, I thought I blew the head gasket!! I poured about 4 litres off coolant and it was back to normal but then I realise there's coolant leaking where my water pump is, I'm not certain it's the water pump but it's all around that area, and it drips down to where my oil sump is what do you guys think and it's not little drips, I turn the car on and it drips a nice puddle in less than a minute :0 I checked my oil and there's no milky or any smoke from exhaust, just a leak, could be thermos housing but the leaks looks more above it thing is my mechanic replaced the water pump, and whole timing kit and also my 3 belt just 1 month ago. So it's still new ! Heres some pictures Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/ Share on other sites More sharing options...
Jonic Posted October 31, 2016 Author Share Posted October 31, 2016 (edited) From the looks of it, the Water pump looks good still, touched it and felt no wetness. I'm thinking i must've destroyed my Head gasket and its leaking from there :S Which im hoping thats not the Case ! P.s When i got the car back from mechanics which was exactly 3 weeks ago, the car was fine no leaks nothing. Then just 2 days ago on the way home from going out, My Oil gauge in the center console went to the middle which is not normal for me. and the ENGINE LIGHT CAME ON ! Then next thing you know, I got no coolant in the Radiator and no coolant in the Reservoir Bottle. And knowing i drove it without any WATER OR COOLANT whatsoever I must've busted the whole leak Bigger cause now when i start the engine not even for a minute you can see the coolant leaking from somewhere at the engine zz I should never have got this car Had way too many problems one after another due to previous owner not taking care of it. Major service i have done before this Leak happen: (Just 3 weeks ago so everything is still new) Timing Belt Kit (Idler Puller & Tension) Replace 3 V-Belts (Alternator, AirCon, PowerSteering) New Water Pump with gasket Replaced ! Valve Cover Gasket ( Rocket Cover ) Thermostat Replaced This was all done professionally at a Mechanic who specialists In SKYLINE AND MANY JAP SPORT CARS so no dodgy job here. Edited October 31, 2016 by Jonic Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7787892 Share on other sites More sharing options...
Duncan Posted October 31, 2016 Share Posted October 31, 2016 It is almost certainly a problem with the water pump install, so take it back and get them to look at it. Other possibilities for loosing all water are a split hose somewhere (which may have been disturbed during the timing belt change, but that's not really their fault). It won't be a head gasket leak, they won't happen externally (ie they will either leak into the cylinder then exhaust, or into the oil). If your mechanic is within a couple of minutes of home just drive it there, the engine will take at least 5 min to get hot without coolant. Keep an eye on the oil temp and stop driving if it gets to normal temp. Otherwise give the mechanic a call and ask them how to get it back to them, since it is likely to be their error. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7787904 Share on other sites More sharing options...
tridentt150v Posted October 31, 2016 Share Posted October 31, 2016 Before you do this, just check your radiator top and bottom hoses are connected, and hose clamps are tight. Also check your hoses for leaks and splits. Also just check that its not your radiator leaking somewhere as well. Even removing the stone tray and seeing where the leak comes from? I agree that the likely culprit is the water pump, but a quick check of the simple things might be a smart move before 'firing from the hip'. 2 Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7787952 Share on other sites More sharing options...
Jonic Posted November 2, 2016 Author Share Posted November 2, 2016 So I took it back to the mechanic and it is the Water Pump, the weep hole was where it was leaking from ! It only got changed 1000kms ago so here's the deal guys, DO NOT BUY REPCO WATER PUMP FOR HIGH PERFORMANCE CARS, it will bust on you ! So need to replace the water pump since it's gone now ! Getting a genuine one from Nissan to be safe! Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788432 Share on other sites More sharing options...
jmknights93 Posted November 2, 2016 Share Posted November 2, 2016 34 minutes ago, Jonic said: So I took it back to the mechanic and it is the Water Pump, the weep hole was where it was leaking from ! It only got changed 1000kms ago so here's the deal guys, DO NOT BUY REPCO WATER PUMP FOR HIGH PERFORMANCE CARS, it will bust on you ! So need to replace the water pump since it's gone now ! Getting a genuine one from Nissan to be safe! That's actually quite interesting to hear. Glad your had your problem sorted. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788448 Share on other sites More sharing options...
admS15 Posted November 2, 2016 Share Posted November 2, 2016 Who purchased the water pump from repco. You or workshop? If it was you and you have to pay for labour again, you can claim warranty through repco including labour costs. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788466 Share on other sites More sharing options...
Jonic Posted November 2, 2016 Author Share Posted November 2, 2016 I purchase the water pump so all goods they can pay me back including labour cause yeah not my fault it was faulty after less than 2 weeks of it getting replaced Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788473 Share on other sites More sharing options...
tridentt150v Posted November 2, 2016 Share Posted November 2, 2016 Out of interest, was it an RB25 one or an RB30 one? Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788569 Share on other sites More sharing options...
Jonic Posted November 2, 2016 Author Share Posted November 2, 2016 It was a rb25det engine, r34 GTT, I only went a little hard a few times after I got it majorly Service (haven't even RED line it yet, how sad) and after a week of driving, next thing you know there was no coolant left and the car over heated bad. I was like wtf seriously !? Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788635 Share on other sites More sharing options...
MrStabby Posted November 3, 2016 Share Posted November 3, 2016 Interesting that Repco even carry RB25 pumps. What brand? Oh and dont forget to return it to them and get your money back Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788760 Share on other sites More sharing options...
Jonic Posted November 3, 2016 Author Share Posted November 3, 2016 They got Repco Brand, WP898RP. They got GMB one which is Japan made but had to order it in and then there's a TRUFLOW brand too. But I got Repco cause I got it really cheap. But you get for what you pay for. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788778 Share on other sites More sharing options...
admS15 Posted November 3, 2016 Share Posted November 3, 2016 You have learned the hard way why people buy genuine 'Nissan only' for those type of parts. As long as you learn from your mistake, you will be a lot better off in the future. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788790 Share on other sites More sharing options...
89CAL Posted November 3, 2016 Share Posted November 3, 2016 Nissan water pumps are cheap enough, $150-$200 is nothing when it should last for 100,000km (ish) I'm fairly sure I've heard of bad reports of repco water pumps before, not that it helps you now but good lesson for others 1 Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788819 Share on other sites More sharing options...
Jonic Posted November 3, 2016 Author Share Posted November 3, 2016 Yeah go for Genuine guys or worst case scenario just get a GMB (Japan) Brand, don't go for anything else people. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7788886 Share on other sites More sharing options...
Jonic Posted November 4, 2016 Author Share Posted November 4, 2016 So I got it replaced with genuine, now have a look at the Repco one that got pulled out 1 Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7789163 Share on other sites More sharing options...
Duncan Posted November 4, 2016 Share Posted November 4, 2016 On 11/2/2016 at 2:40 PM, Jonic said: I purchase the water pump so all goods they can pay me back including labour cause yeah not my fault it was faulty after less than 2 weeks of it getting replaced So are repco covering all your costs? Or is that yet to be seen? Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7789236 Share on other sites More sharing options...
tridentt150v Posted November 5, 2016 Share Posted November 5, 2016 On 2/11/2016 at 8:43 PM, tridentt150v said: Out of interest, was it an RB25 one or an RB30 one? No, I meant the water pump itself, they are slightly different and REPCO and others often carry the one for the RB30, but rarely stock the proper one for the RB25. Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7789315 Share on other sites More sharing options...
Jonic Posted December 14, 2016 Author Share Posted December 14, 2016 It's funny cause before I change the water pump the check engine light came on, I'm assuming it's the coolant temperature sensor Acting up when I had no coolant. Now the car is running on a Limp mode how sad. Too many problems with this R34 >.> Link to comment https://www.sau.com.au/forums/topic/467533-coolant-leaking-r34-gtt/#findComment-7798444 Share on other sites More sharing options...
