FS: R34 GT-T front brakes
* 310mm ventilated discs + calipers
* pads included (dont know what brand)
* discs in excellent condition - not scored, warped or cracked
$750.
email [email protected]
Melbourne buyers only (located near CBD).
https://www.sau.com.au/forums/topic/46754-fs-r34-gt-t-front-brakes/
  • Replies 40
I think if you look outside of melbourne you may have a bit more luck
OK. Interstate buyers welcome :)
Postage can not be via Australia Post as the discs + calipers weigh over 20kg limit.
Courier delivery through somewhere like Pack'n'Send will be about $60-$70.
seperate boxes mate, I sent 17" wheels via AP no problems
/end chatting
cool, wasnt sure about sending them seperately in case one box gets lost... Doesnt look like much interest from interstate anyway.
how old are the rotors? have they been on the car for long?
dont know how many km's the rotors have done exactly.. they were on the car when it came from Japan. they're in very good condition as already mentioned.
I'm not planning to seperate so if you're interested in buying the rotors you will need to buy them with the calipers....
]']they bigger than the
32 GTR brakes?
or r they 32 have better 1's..
sorry about the Q..
i'mma noob :)
Look up the info yourself dude... I dont know about R32 brakes. Are they brembo?
If the discs are larger than 310mm diameter then they're bigger.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
