Failed rego transfer, can't find import and seating plate on E51 Elgrand
Just tried to transfer rego for an Elgrand I picked up interstate (NSW car, trying to rego in TAS). Mechanic couldn't find the Import plate, or the Seating plate, and also said the VIN number (under panel beside driver seat) was the Japanese one, and not the "modified Australian VIN with extra digits".
Anyone have any ideas? I transferred the rego in NSW into my name no problems when I bought the car, then moved down to Tas and tried to transfer it to local rego here and no luck.
Rego papers match Jap VIN and have the extra numbers in front, so it's obviously somewhere on the car and was found previously to rego it in NSW. I've looked all under the bonnet, and anywhere else I can think of, and they put it on the hoist and looked around underneath and can't find anything.
I didn't get any import papers with it, it was imported a while ago and passed through a couple owners since then. Previous owner doesn't have a clue either, bought it rego'd and just re-regoed with no issues.
Thanks in advance.
On 10/11/2016 at 2:53 PM, DJBarnstar said:
It is probably regoed as a campervan. My one was. You will need an engineering certificate, and that guy will put the right plate on.
This is exactly what it ended up being, and it's booked in for a mod plate to make it all proper for rego. They said it's still supposed to have an import sticker, but since it's just a sticker, they fall off apparently.. and they're accepting the old rego papers as proof the VIN/etc matches properly. I was lucky the previous owner left the old rego papers in the glovebox.
  • Like 1
22 hours ago, DJBarnstar said:
8ea096ee9ae62e31ddb3d96465698e37.jpg This is our Autech. Post a pic!
That's nice! I wish I could've got a Highwaystar or one of the fancier ones but resisted and got a cheapie so my money can go on the Stagea.
This is the only pic I've got so far (it's still stock/boring so haven't taken many pics)..
Edited by Sierra
  • Like 1
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
