Yotis...what's your caper? Why don't you have a car?
By the way it's still gonna be a couple of months away...so lots of prep time ;)
Glows sticks...all the colours of the rainbow :)
My friend too much happend in the last few weeks, suffice to say I hate rain now....
Yeah it is a fair way away.. hopefully then I will have a car again. :D
Hmmm dunno about that softcore 80's music...maybe some of the later old-school rave stuff....will have to dig around a bit. Some old prodigy....moving into more of the current dance stuff really.....some of the earlier Ministry of Sound would be quite good....even the current stuff.
All input quite welcome :D
Yeah hard energy are good. I'd hate to admit it...but scooter has actually got the typical sound of 89 in most of his tracks...but let's face it he's a crazy German that spouts crap :( Anyone who says "the painted cow" and "it must be dave on a train"???? has got serious issues...don't believe me then check out his lyrics :D
Don't forget "Respect to the man in the ice cream van" - Scooter
Will be there FOR SURE!!!!
Music hmmm - Early off some commercial dance/house R'N'B moving into Ministery/Skitz/Becstar/ moving into happy house followed by hard house followed by ministery chillout around 5am onwards ----- What a night
Scott brown
Dj Hixxy
Bonkers
Dj Weirdo & Captain tinrib
Godskitchen&Gatecrasher
Slinky&Delerium
Ferry Corsen
Tiesto
Anything from the human traffic soundtrack :)
Scooter
Prodigy
Any tidy trax
Dyewitness
Kevin Energy
And throw in some cool new mixes of old songs.. like vietnam war song techno remixes :) If u know what i mean
and oh yeah, can anyone get some coke?
a cola :D :aroused: :alcoholic
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
