  • Replies 76
Just blinked out the codes using the instructions in this link: http://www.gtr.co.uk/forum/123312-reading-ecu-fault-codes.html
5 long blinks, 5 fast blinks: No Malfunction
Time to turn my focus to the fuel system?
Am I not able to edit posts after a certain period of time?
At any rate, I will be testing fuel pressure at at the rail tonight or tomorrow, how much pressure should I see? 3 kg/cm2 (42psi)?
Edited by planrforrobert
Stock FP readings should be:
@ ignition switch ON:   approx 3.0 kg/cm2
@ Engine idling:   approx 2.5 kg/cm2
@ idling, disconnect vacuum hose at FPR:   approx 3.0 kg/cm2
A known good CAS landed at the shop today, installed it correctly...no change.  Will still crank and crank but no start.  Will be checking fuel pressure as well as testing to see if I have spark going to the coil packs tomorrow night.
So, progress!
Pushed the car into the shop tonight and was set on confirming I had spark and fuel. Started with fuel. Pulled feed line off fuel rail...it's dry. Did some testing of the pump wiring and everything pointed to the fuel pump being bad. To confirm the wiring wasn't the issue we pulled the pump out:
Used a power probe to try and run the pump out of the car, it's dead. I'll get a new pump on order and (hopefully) finally get to enjoy my car.
So that's how a properly-fed RB should run, haha.
New pump and tank gasket install was a breeze and the car fired up first try. It's like driving a brand new 25-year old car.  Throttle response is there and it pulls pulls pulls.  Thanks all for the help/insight suggestions!
  • 4 weeks later...
Good to hear, mine is going they similar stage I started with the coil pack and did plugs too but not really much change, what kind of pump you get? And how much was it ?
I went with this pump:
IMG_4704.thumb.JPG.fc91d97b43214f2a0e78a
Any Walbro 255 or similar pump will work, and wiring is very straightforward. I am by no means a savvy mechanic, but install took me about 45 minutes (and that included cleaning surface rust off the sending unit). Make sure to replace the tank seal if you're in there.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
