  • Replies 76
Just blinked out the codes using the instructions in this link: http://www.gtr.co.uk/forum/123312-reading-ecu-fault-codes.html
5 long blinks, 5 fast blinks: No Malfunction
Time to turn my focus to the fuel system?
Am I not able to edit posts after a certain period of time?
At any rate, I will be testing fuel pressure at at the rail tonight or tomorrow, how much pressure should I see? 3 kg/cm2 (42psi)?
Edited by planrforrobert
Stock FP readings should be:
@ ignition switch ON:   approx 3.0 kg/cm2
@ Engine idling:   approx 2.5 kg/cm2
@ idling, disconnect vacuum hose at FPR:   approx 3.0 kg/cm2
A known good CAS landed at the shop today, installed it correctly...no change.  Will still crank and crank but no start.  Will be checking fuel pressure as well as testing to see if I have spark going to the coil packs tomorrow night.
So, progress!
Pushed the car into the shop tonight and was set on confirming I had spark and fuel. Started with fuel. Pulled feed line off fuel rail...it's dry. Did some testing of the pump wiring and everything pointed to the fuel pump being bad. To confirm the wiring wasn't the issue we pulled the pump out:
Used a power probe to try and run the pump out of the car, it's dead. I'll get a new pump on order and (hopefully) finally get to enjoy my car.
So that's how a properly-fed RB should run, haha.
New pump and tank gasket install was a breeze and the car fired up first try. It's like driving a brand new 25-year old car.  Throttle response is there and it pulls pulls pulls.  Thanks all for the help/insight suggestions!
  • 4 weeks later...
Good to hear, mine is going they similar stage I started with the coil pack and did plugs too but not really much change, what kind of pump you get? And how much was it ?
I went with this pump:
IMG_4704.thumb.JPG.fc91d97b43214f2a0e78a
Any Walbro 255 or similar pump will work, and wiring is very straightforward. I am by no means a savvy mechanic, but install took me about 45 minutes (and that included cleaning surface rust off the sending unit). Make sure to replace the tank seal if you're in there.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
