  • Replies 76
Just blinked out the codes using the instructions in this link: http://www.gtr.co.uk/forum/123312-reading-ecu-fault-codes.html
5 long blinks, 5 fast blinks: No Malfunction
Time to turn my focus to the fuel system?
Am I not able to edit posts after a certain period of time?
At any rate, I will be testing fuel pressure at at the rail tonight or tomorrow, how much pressure should I see? 3 kg/cm2 (42psi)?
Edited by planrforrobert
Stock FP readings should be:
@ ignition switch ON:   approx 3.0 kg/cm2
@ Engine idling:   approx 2.5 kg/cm2
@ idling, disconnect vacuum hose at FPR:   approx 3.0 kg/cm2
A known good CAS landed at the shop today, installed it correctly...no change.  Will still crank and crank but no start.  Will be checking fuel pressure as well as testing to see if I have spark going to the coil packs tomorrow night.
So, progress!
Pushed the car into the shop tonight and was set on confirming I had spark and fuel. Started with fuel. Pulled feed line off fuel rail...it's dry. Did some testing of the pump wiring and everything pointed to the fuel pump being bad. To confirm the wiring wasn't the issue we pulled the pump out:
Used a power probe to try and run the pump out of the car, it's dead. I'll get a new pump on order and (hopefully) finally get to enjoy my car.
So that's how a properly-fed RB should run, haha.
New pump and tank gasket install was a breeze and the car fired up first try. It's like driving a brand new 25-year old car.  Throttle response is there and it pulls pulls pulls.  Thanks all for the help/insight suggestions!
  • 4 weeks later...
  On 13/12/2016 at 10:56 AM, R33gtst2016 said:
Good to hear, mine is going they similar stage I started with the coil pack and did plugs too but not really much change, what kind of pump you get? And how much was it ?
I went with this pump:
IMG_4704.thumb.JPG.fc91d97b43214f2a0e78a
Any Walbro 255 or similar pump will work, and wiring is very straightforward. I am by no means a savvy mechanic, but install took me about 45 minutes (and that included cleaning surface rust off the sending unit). Make sure to replace the tank seal if you're in there.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
