  • Replies 76
  On 17/12/2016 at 2:37 AM, R33gtst2016 said:
Or is it not a gasket just sealant ?
Expand
do not ever use sealant, you'll end up in a sad financial mess if you do.
OEM seal or OEM seal those are your options.
Note the S14 and S15 seal fits too on your R33 R34
So I've f**ked up along the way somewhere I changed it over I thought all went well, but won't start, cranks over but doesn't start tonight after work I gotta take it back out and double check my wiring were right positive to positive n negative to negative, there's a dash light on but I dno what it is
That tells you when your Cat Coverter is blocked (there is a temp probe in the Cat that sets off the light at a certain temp)
Could it be a Cat problem? If that is coming up when you are trying to crank I doubt it. I'd only expect it to come up after the car is driven for a bit
Are you hearing the pump run? If no it may be a wiring issue. I remember remarking at how brittle/fragile some of the fuel pump wiring was, maybe something has broken with those. If you are hearing the pump run I would pull the whole assembly back out and make sure everything is installed as it should be.
I would confirm you are hearing the pump first. Then, if you are, pull the fuel line going to the fuel rail off and try to crank it and see how strong of a stream you have (you may want to just test for pressure).
If those tests "fail" then I would pull the pump out and inspect everything.
Not sure if its the same on R32's but on my R33 if i turn the key about halfway between on and start and hold it there the fuel pump runs. Did so with Power FC anyway and the Link does it to however cuts the pump after a few seconds
What would happened when I try to start the car if I didn't put the hoses on correctly? I've checked I can defiantly hear the pump, but still won't start just cranks, thought that I've put everything back the way it was originally but don't understand why won't start. Any ideas
Maybe you have the inlet and outlet hoses crossed? On the 32s that space is tight and they could easily get crossed. Easiest way to check is to pull fuel line going to rail and reroute it into a bucket. If you can crank it and fuel comes out, you know they are plumbed correctly.
Also, what condition is your fuel filter in? A clogged filter could give you grief as well.
If you took the hoses off at the pump and aren't getting any flow, the issue is in the tank. If the pump was working correctly you'd have fuel everywhere.
To answer your last question, you want to focus on the hose between the filter and the rail, removing it from where it connects to the rail.
But start at the tank, it sounds like your pump isn't pumping.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
